[mesh manipulation] mergeMeshes orthogonality
Old   March 5, 2013, 22:17
Default mergeMeshes orthogonality
antoniofct is on a distinguished road
Hi people..
I am trying to merge two meshes with the faces where they are about to be merged to keep their boundaries. So mergeMeshes is what I need.
What happens is that each one of the meshes has high quality and when I merge them, a lot of non-orthogonal faces appear. To make this issue even more disturbing, the non-orthogonal faces are not where the meshes merge, which I could at least understand...
Now..do you have any idea of what is happening or how to overcome this? Other than trying to build new meshes...
Thanks!
Antonio
antoniofct is offline   Reply With Quote
Old   July 30, 2013, 07:10
Eloïse
Eloise is on a distinguished road
Hi Antonio,
Have you solved this issue of non orthogonal faces? I observe the same in my cases.
Regards,
Eloïse
Eloise is offline   Reply With Quote
Old   July 30, 2013, 07:58
No. I had to build the mesh from scratch.
[Other] mergeMeshes in OpenFOAM extend nwpukaka OpenFOAM Meshing & Mesh Conversion 0 April 19, 2016 23:09
[mesh manipulation] MergeMeshes hsieh OpenFOAM Meshing & Mesh Conversion 3 September 10, 2014 09:15
[ICEM] Improving mesh orthogonality in ICEM or Fluent Harshal ANSYS Meshing & Geometry 0 December 2, 2013 09:04
[ANSYS Meshing] Orthogonality and grid expansion control Shylock ANSYS Meshing & Geometry 3 February 15, 2012 14:14
Orthogonality Angle Tristan CFX 2 December 2, 2008 12:11
