[mesh manipulation] cyclic patches with different no. of faces - snappyHexMesh - createPatch
Old   September 16, 2013, 11:02
Default cyclic patches with different no. of faces - snappyHexMesh - createPatch
KYPCK444 is on a distinguished road
My aim is to set cyclic boundaries to meshes created with snappyHexMesh, by means of createPatch utility.
The problem arises when patches to be joined (say inlet and outlet of a pipe) have different number of faces, which is a result of the mesh: createPatch gives what follows:
--> FOAM Serious Error :
From function cyclicPolyPatch:rder(const primitivePatch&, labelList&, labelList&) const
in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 1383
Patchutlet_cyclic : Cannot match vectors to faces on both sides of patch
Perhaps your faces do not match? The obj files written contain the current match.
Continuing with incorrect face ordering from now on!
--> FOAM FATAL ERROR:
For patch inlet_cyclic there are 7269 face centres, for the neighbour patch outlet_cyclic there are 7398
From function cyclicPolyPatch::calcTransforms()
in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 160.
FOAM exiting
Does anyone know how to proceed in such a case?
thanks
KYPCK444 is offline   Reply With Quote
Old   September 27, 2013, 07:13
ok,
the answer was:
use cyclicAMI conditions ----> http://www.cfd-online.com/Forums/ope...ber-faces.html
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 09:23
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
[snappyHexMesh] SHM is not extruding/adding Layers everywhere matthiasd OpenFOAM Meshing & Mesh Conversion 2 October 16, 2016 16:45
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
[snappyHexMesh] snappyHexMesh with cyclic patches? Axel_T OpenFOAM Meshing & Mesh Conversion 1 October 12, 2010 10:03
