Home > Forums > OpenFOAM Meshing & Mesh Conversion
mesh spatial dimension in OpenFOAM
Like Tree1Likes
  • 1 Post By nimasam
Old   September 20, 2013, 16:53
Default mesh spatial dimension in OpenFOAM
Reno
jr33 is on a distinguished road
My default mesh geometry length is in 80 mm. For OpenFoam, I scaled the mesh in meters as 0.008 m. Once I import the mesh in OpenFOAM, it is a collection of point coordinates. Now, the location of these points and spatial difference between different points will be the same either if they are in mm or m. I feel spatial unit is arbitrary here?
I want to understand when do I have to scale the geometry in Openfoam and when not?
jr33 is offline   Reply With Quote
Old   September 29, 2013, 03:25
Nima Samkhaniani
nimasam is on a distinguished road
well, when you import your mesh, use checkMesh
then you will see the scale of your geometry, if it differs from what you intended then you can use transformPoints -scale '(x x x)'
where x is your scale.
lav likes this.
Telegram channel (https://telegram.me/openfoam4Iranian)
My Weblog (http://openfoam.blogfa.com/)
Training Course on OpenFOAM at (http://www.isme.ir/)
nimasam is offline   Reply With Quote
Old   October 2, 2013, 01:00
Reno
Thanks, that helps.
Old   Yesterday, 11:57
Ram
Scram_1 is on a distinguished road
Hey,
I have a question regarding the fluentMeshToFoam command. My geometry is in mm and I've created the mesh in ICEM. Now after doing fluentMeshToFoam pipe.msh I do checkMesh. Now, checkMesh gives the dimensions of the overall bounding box without the units. Are these units in mm since my geometry is in mm? or if I want to convert it into mm should I do transformPoints -scale '(0.001 0.001 0.00)'?
For example, when I go to the scale option in fluent, it asks me the units in which my mesh was created and accordingly scales the mesh. What I mean by scale is, it keeps the numbers the same just changes the units. In openFOAM, when I do checkMesh, it gives me the same dimensions without the units. So I don't know what the units are., whether it is m or mm.
Thanks!!
Ram
Scram_1 is offline   Reply With Quote
Old   Yesterday, 11:59
Ram
I meant transformPoints -scale'(0.001 0.001 0.001)' in the previous post
Thread Tools
Trackbacks are On
Mesh conversion Salome to OpenFOAM VMartinez OpenFOAM Meshing & Mesh Conversion 11 April 21, 2014 02:54
can prism elements exist in 2D mesh in openfoam shuoxue OpenFOAM Meshing & Mesh Conversion 2 June 20, 2013 23:19
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
