[blockMesh] block with 6 vertices
Old   October 5, 2013, 04:10
Default block with 6 vertices
Hale
Hale is on a distinguished road
Hi
I'm trying to create a block with 6 vertices. I followed the instruction on page U-142 in the user Guide but I got some strange shape of the block. I guess it is because it assumes that the vertices on the collapsed side have the same y values, which is not the case in my problem.
I have attached a sketch of the geometry. There is no problem defining the 8-cornered blocks at the sides but the 6-cornered blocks are not easy to define if they have to have the right x, y, and z direction as the other 8-cornered blocks.
I tried the following:
8-cornered blocks
hex (7 3 11 15 4 0 8 12)
hex (0 1 9 8 4 5 13 12)
hex (2 6 14 10 1 5 13 9)
hex (7 6 14 15 3 2 10 11)
6-cornered blocks
hex (1 0 8 9 1 2 10 9)
hex (3 2 10 11 3 0 8 11)
This gives the right geometry but when I run the simulation it takes 20 times as much time to get results as when I remove the triangles in the middle and just define a square block!
Am I defining something wrong the two last blocks?
NB. I need these triangular blocks to define a wall in the middle afterwards.
Hale is offline   Reply With Quote
Old   October 5, 2013, 08:00
Retired Super Moderator
Bruno Santos
Greetings Hale,
If you could provide an example case, it would be easier to experiment this ourselves.
Beyond this, my suggestion is to step back a few steps and use the cavity tutorial as an example for gradually creating collapsed edges. For example:
  1. First split the square-like mesh into 2 triangles.
  2. Then split it again into 4 triangles.
  3. Then finally evolve to the mesh you want.
Best regards,
Bruno
[ICEM] Scripting: Naming of block vertices ayoung94 ANSYS Meshing & Geometry 1 April 20, 2018 04:33
[blockMesh] Mixer mesh - negative volume problem jadtwo OpenFOAM Meshing & Mesh Conversion 2 November 6, 2014 16:37
foamLog not solving for Ux, Uy, Uz aerospain OpenFOAM Post-Processing 5 April 18, 2012 10:01
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 02:58
[blockMesh] How to construct a block with four vertices jennyrui2008 OpenFOAM Meshing & Mesh Conversion 0 November 5, 2008 20:44
