August 21, 2015, 06:22 |
Tutorial simpleFoam pipeCyclic
Frankreich
Hello everybody,
I'm trying to learn OpenFoam and I'm using CAE linux, I've read the user guide and I'm now trying to work on the simpleFoam pipeCyclic. Firstly I go in the working directory using cd.... them I use blockMesh and I obtain this error message that I don't really understand. Can you explain me this please? Thanks per advance Jocelyn /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.1-221db2718bbb Exec : blockMesh Date : Aug 21 2015 Time : 13:07:54 Host : "desouza-F5VL" PID : 3965 Case : /home/de-souza/OpenFOAM/de-souza-2.1.1/run/i nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Creating block mesh from "/home/de-souza/OpenFOAM/de-souza-2.1.1/run/i/constant/polyMesh/blockMeshDict" Using #calcEntry at line 26 in file "/home/de-souza/OpenFOAM/de-souza-2.1.1/run/i/constant/polyMesh/blockMeshDict" --> FOAM FATAL IO ERROR: Loading a shared library using case-supplied code is not enabled by default because of security issues. If you trust the code you can enable this facility be adding to the InfoSwitches setting in the system controlDict: allowSystemOperations 1 The system controlDict is either ~/.OpenFOAM/$WM_PROJECT_VERSION/controlDict or $WM_PROJECT_DIR/etc/controlDict file: /home/de-souza/OpenFOAM/de-souza-2.1.1/run/i/constant/polyMesh/blockMeshDict from line 17 to line 23. From function functionEntries::calcEntry::execute(..) in file db/dynamicLibrary/dynamicCode/dynamicCode.C at line 81. FOAM exiting |
August 21, 2015, 07:53 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: You have to run the script Allrun:
./Allrun You can find more details for a similar tutorial case here: http://www.cfd-online.com/Forums/ope...tml#post446405 - post #23 |
Display Modes | |
How to run in transient the airFoil2D (simpleFoam) tutorial case? | csacska | OpenFOAM Running, Solving & CFD | 5 | June 19, 2017 08:45 |
[Tutorials] New Dakota - OpenFOAM Coupling Tutorial | Tobi | OpenFOAM Community Contributions | 0 | October 9, 2016 17:19 |
Problem With using snappyhexmesh and getting simplefoam to work. | Ivanj56 | OpenFOAM Running, Solving & CFD | 0 | March 22, 2016 06:20 |
simpleFoam symbol lookup error | botobeno | OpenFOAM Running, Solving & CFD | 3 | September 6, 2011 14:07 |
STAR-CD Tutorial | shekhar aryal | STAR-CD | 4 | March 22, 2010 03:25 |
