[Other] problem in axisymmetric Mesh.
Old   October 27, 2013, 02:58
Default problem in axisymmetric Mesh.
sajad
seju is on a distinguished road
Greetings to all.
I want run this mesh but I see the error.
PHP Code:
/*--------------------------------*- C++ -*----------------------------------*\
| \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox           |
|  \\    /   O peration     | Version:  2.2.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
|    \\/     M anipulation  |                                                 |
FoamFile
version     2.0;
format      ascii;
    class
dictionary;
object      blockMeshDict;
convertToMeters 0.012;
vertices
0 0 0)
0.0999 0.04362 0)
0.0999 0.04362 5
0 0 5)
0.0999 -0.04362 0
0.0999 -0.04362 5)
blocks
hex (0 4 1 0 3 5 2 3) (40  1 200simpleGrading (1 1 1)
edges
boundary
front
type wedge;
faces
0 1 2 3)
back
type wedge;
faces
0 3 5 4)
fixedkWall
type wall;
faces
1 4 5 2)
bottom
type patch;
faces
0 4 1 0)
top
type patch;
faces
3 2 5 3)
axis
type empty;
faces
0 3 3 0)
mergePatchPairs
ERROR:
PHP Code:
Build  2.2.1-57f3c3617a2d
Exec
blockMesh
Date
Oct 28 2013
Time
10:24:38
Host
"sajad-K55VD"
PID    7306
Case   : /home/sajad/OpenFOAM/sajad-2.2.1/run/tutorials/multiphase/interFoam/laminar/ellipsoidal
nProcs
1
sigFpe
Enabling floating point exception trapping (FOAM_SIGFPE).
fileModificationChecking Monitoring run-time modified files using timeStampMaster
allowSystemOperations
Disallowing user-supplied system call operations
Create time
Creating block mesh from
"/home/sajad/OpenFOAM/sajad-2.2.1/run/tutorials/multiphase/interFoam/laminar/ellipsoidal/constant/polyMesh/blockMeshDict"
Creating curved edges
Creating topology blocks
Creating topology patches
Creating block mesh topology
--> FOAM FATAL ERROR
face 0 in patch 4 does not have neighbour cell face4(3 2 5 3)
From function polyMesh::facePatchFaceCells(const faceListpatchFaces,const labelListListpointCells,const faceListListcellsFaceShapes,const label patchID)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 127.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::polyMesh::facePatchFaceCells(Foam::List<Foam::face> const&, Foam::List<Foam::List<int> > const&, Foam::List<Foam::List<Foam::face> > const&, int) const at ??:?
#3  Foam::polyMesh::setTopology(Foam::List<Foam::cellShape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::List<int>&, Foam::List<int>&, int&, int&, Foam::List<Foam::cell>&) at ??:?
#4  Foam::polyMesh::polyMesh(Foam::IOobject const&, Foam::Xfer<Foam::Field<Foam::Vector<double> > > const&, Foam::List<Foam::cellShape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::PtrList<Foam::dictionary> const&, Foam::word const&, Foam::word const&, bool) at ??:?
#5  Foam::blockMesh::createTopology(Foam::IOdictionary const&, Foam::word const&) at ??:?
#6  Foam::blockMesh::blockMesh(Foam::IOdictionary const&, Foam::word const&) at ??:?
at ??:?
#8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
at ??:?
Aborted (core dumped
you can see similar mesh in this link
HTML Code:
http://openfoamwiki.net/index.php/Main_ContribExamples/AxiSymmetric
I even copy that code from above link and I saw this error again.
after change polyMesh in terminal I run: blockMesh
is it wrong?
where is my drawback??
*best regards*
sajad
seju is offline   Reply With Quote
Old   November 2, 2013, 22:48
Default Using wedge elements
Nucleophobe is on a distinguished road
Sajad,
In order to create wedge elements with blockMesh, you must be careful to follow the guidelines provided in the OpenFOAM documentation (5.3.3):
http://www.openfoam.org/docs/user/blockMesh.php
Also, note that when specifying patches,
The order in which the vertices are given must be such that, looking from inside the block and starting with any vertex, the face must be traversed in a clockwise direction to define the other vertices.
I'm not sure where the problem was, but this works:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
vertices
(0.0999 -0.04362 0) // new 0, old 4
(0.0999 -0.04362 5) // new 1, old 5
(0.0999 0.04362 5) // new 2, old 2
(0.0999 0.04362 0) // new 3, old 1
(0 0 0) // new 4, old 0
(0 0 5) // new 5, old 3
// Old vertices:
//(0 0 0) //0
//(0.0999 0.04362 0) //1
//(0.0999 0.04362 5) //2
//(0 0 5) //3
//(0.0999 -0.04362 0) //4
//(0.0999 -0.04362 5) //5
blocks
hex (0 1 2 3 4 5 5 4) (40  1 200) simpleGrading (1 1 1)
edges
boundary
     front
           type wedge;
           faces
               (0 1 5 4)
     back
           type wedge;
           faces
               (2 3 4 5)
     fixedkWall
           type wall;
           faces
               (0 1 2 3)
     bottom
           type patch;
           faces
               (1 2 5 5)
     top
           type patch;
           faces
               (0 3 4 4)
     axis
           type empty;
           faces
               (4 5 5 4)
mergePatchPairs
Finally, before you use this mesh in a simulation, you will want to modify the geometry such that the angle between the 'front' and 'back' patches is ~5 degrees:
wedge
For 2 dimensional axi-symmetric cases, e.g. a cylinder, the geometry is specified as a wedge of small angle (e.g. ) and 1 cell thick running along the plane of symmetry, straddling one of the coordinate planes, as shown in Figure 5.4. The axi-symmetric wedge planes must be specified as separate patches of wedge type. The details of generating wedge-shaped geometries using blockMesh are described in section 5.3.3.
(http://www.openfoam.org/docs/user/boundaries.php)
As defined, the angle is closer to 25 degrees. You can check this with 'checkMesh' :
Checking geometry...
    Overall domain bounding box (0 -0.00052344 0) (0.0011988 0.00052344 0.06)
    Mesh (non-empty, non-wedge) directions (1 0 1)
    Wedge front with angle 23.587845 degrees
    Wedge back with angle 23.587845 degrees
    All edges aligned with or perpendicular to non-empty directions.
    Boundary openness (-8.8718496e-14 -3.0464533e-16 -1.9670129e-19) OK.
    Max cell openness = 2.5596435e-16 OK.
    Max aspect ratio = 500.5005 OK.
    Minimum face area = 1.5687497e-11. Maximum face area = 1.57032e-06.  Face area magnitudes OK.
    Min volume = 2.3531245e-14. Max volume = 9.3889668e-12.  Total volume = 3.7649992e-08.  Cell volumes OK.
    Mesh non-orthogonality Max: 0 average: 0
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 1.0915773 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
Good luck,
-Nuc
Nucleophobe is offline   Reply With Quote
Old   November 25, 2014, 11:23
Default Negative pyramid volume warning
Vignesh
vigneshTG is on a distinguished road
Dear All,
I am trying to create an axisymmetric mesh. The blockMeshDict i edited is shown below.
|  \\    /   O peration     | Version:  2.0.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
// angle 5 deg
// radius 1
convertToMeters 1;
vertices
    (0 0 0)
    (0.49952 0 0.02180)
    (0.49952 1 0.02180)
    (0 1 0)
    (0.49952 0 -0.02180)
    (0.49952 1 -0.02180)
blocks
    hex (0 4 1 0 3 5 2 3) (60 1 60) simpleGrading (1 1 1)
edges
boundary
    front
           type wedge;
           faces
               (0 1 2 3)
     back
           type wedge;
           faces
               (0 3 5 4)
     sideWall
           type wall;
           faces
               (1 4 5 2)
     bottom
           type wall;
           faces
               (0 4 1 0)
     top
           type patch;
           faces
               (3 5 2 3)
     axis
           type empty;
           faces
               (0 3 3 0)
mergePatchPairs
When i run blockMesh, i get the following warning of negative pyramid volume
--> FOAM Warning :
    From function cellModel::mag(const labelList&, const pointField&)
    in file meshes/meshShapes/cellModel/cellModel.C at line 128
    zero or negative pyramid volume: -0.00362985 for face 1
--> FOAM Warning :
    zero or negative pyramid volume: -0.00181492 for face 2
--> FOAM Warning :
    zero or negative pyramid volume: -0.00181492 for face 3
--> FOAM Warning :
    zero or negative pyramid volume: -0.00181492 for face 4
--> FOAM Warning :
    zero or negative pyramid volume: -0.00181492 for face 5
--> FOAM Warning :
    From function blockMesh::createTopology(IOdictionary&)
    in file blockMesh/blockMeshTopology.C at line 255
    negative volume block : 0, probably defined inside-out
Can someone tell me what i am doing wrong !!
Thanks and Regards
Vignesh
vigneshTG is offline   Reply With Quote
[ICEM] Problem with using the Delaunay volume mesh method manahara ANSYS Meshing & Geometry 12 December 25, 2014 21:54
[ICEM] problem in mesh output mehrzad ANSYS Meshing & Geometry 2 December 10, 2014 18:07
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 08:52
