[Commercial meshers] Failed checkMesh - ICEM converted mesh
Like Tree1Likes
  • 1 Post By Thangam
Old   November 27, 2013, 06:32
Default Failed checkMesh - ICEM converted mesh
Eleanor Rajaratnam
elebelly is on a distinguished road
Hi, I just converted my mesh (created on ICEM) however when I run the checkMesh command, it results in:
Checking geometry...
Overall domain bounding box (-11996.5928 -12000 -399.9727429) (20000 12000 399.9727429)
Mesh (non-empty, non-wedge) directions (1 1 0)
Mesh (non-empty) directions (1 1 0)
All edges aligned with or perpendicular to non-empty directions.
Boundary openness (-4.626143897e-18 -4.831227775e-18 -5.071408981e-19) OK.
***High aspect ratio cells found, Max aspect ratio: 11533.97369, number of cells 25089
<<Writing 25089 cells with high aspect ratio to set highAspectRatioCells
Minimum face area = 1.243221387e-05. Maximum face area = 303119.0509. Face area magnitudes OK.
Min volume = 0.009945093367. Max volume = 65443544.43. Total volume = 5.648098245e+11. Cell volumes OK.
Mesh non-orthogonality Max: 86.68018587 average: 9.268946233
*Number of severely non-orthogonal faces: 267.
Non-orthogonality check OK.
<<Writing 267 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
Max skewness = 0.9275708721 OK.
Coupled point location match (average 0) OK.
Failed 1 mesh checks.
End
Why has it failed? And what can be done to resolve this?
Any help is really appreciated,
Ele
elebelly is offline   Reply With Quote
Old   November 27, 2013, 07:44
Default Simple Solution
skyinventorbt's Avatar
Dr. B T KANNAN
skyinventorbt is on a distinguished road
Face pyramids OK.
End
Ele
Dear Ele,
"Try to increase the number of cells or reduce the grading" to avoid aspect ratio error.
KANNAN
skyinventorbt is offline   Reply With Quote
Old   December 11, 2013, 02:53
Thangam Natarajan
Thangam is on a distinguished road
After the checkMesh, you could use foamToVTK utility to visualize all the non ortho faces and the high aspect ratio cells in paraview. In your case, run the command foamToVTK -faceSet highAspectRatioCells and this will create a VTK folder (which has the .VTK file) in your case directory which can then be visualized in paraview to see the cells containing high aspect ratio and you could rework/correct your geometry in ICEM if you want.(atleast you would know where the bad cells are!). You can repeat this for the non ortho faces as well.
good luck.
A H Gazi likes this.
Thangam is offline   Reply With Quote
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
GAMG crash fxzf OpenFOAM Running, Solving & CFD 6 June 5, 2018 05:09
Parametric Mesh with ICEM and Workbench fails to update fabian.schicker ANSYS 0 May 9, 2017 08:20
FLUENT adding mesh nodes problem when importing 3D mesh from ICEM guxin7005 FLUENT 2 June 27, 2016 21:41
Unstructured Mesh ICEM on a cube jerome_ ANSYS 0 May 30, 2012 05:34
