[blockMesh] Problems meshing a half of a cylinder with blockMesh |
November 25, 2013, 10:47 |
Alex
Rep Power: 21 |
Hi FOAMers!
I'm trying to mesh a geometry formed by a half of a cylinder and a cube (the way you can see in the attached file). Although I've done the mesh, as you can see in the pic attached, I have had a little problem and I don't know what to do about that. The thing is that it forces me to divide the blocks 1 and 2 in the same amount of cells in the angular direction that block 0 is. Otherwise I get the following error message: Code:
--> FOAM FATAL ERROR: Inconsistent number of faces between block pair 0 and 2 From function blockMesh::calcMergeInfo() in file blockMesh/blockMeshMerge.C at line 221. Another curious fact I have found is that the internal faces between blocks 0 and 1, 2 and betwen block 3 and 1,2 are considered as default faces (empty) after executing blockMesh (as you can see in the attached pic). I don't know if it can cause some trouble when computing with laplacianFoam or not. If so, I would like to know how to solve that. This is my blockMeshDict file: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // /* Mapa conceptual ·2/11 /|\ / | \ 3/12. .8 \ /7. |17 \ / 16 | \ 4\13·____.____·1/10 | |0/9 5/14.____.6/15 */ convertToMeters 0.001; vertices ( (0 0 0) //vertice 0 (30 0 0) // 1 (0 30 0) // 2 (-21.213203436 21.213203436 0) // 3 (-30 0 0) // 4 (-30 -10 0) // 5 (0 -10 0) // 6 (-14.142135624 14.142135624 0) // 7 (0 20 0) // 8 (0 0 10) //vertice 9 -> 0' (30 0 10) // 10 -> 1' (0 30 10) // 11 -> 2' (-21.213203436 21.213203436 10) // 12 -> 3' (-30 0 10) // 13 -> 4' (-30 -10 10) // 14 -> 5' (0 -10 10) // 15 -> 6' (-14.142135624 14.142135624 10) // 16 -> 7' (0 20 10) // 17 -> 8' ); blocks ( hex (0 0 1 2 9 9 10 11) base (4 3 1) simpleGrading (1 1 1) // bloc 0, 1/2 de peça hex (2 3 7 8 11 12 16 17) generacio (4 1 1) simpleGrading (1 1 1) // bloc 1, generació hex (0 0 8 7 9 9 17 16) base (4 2 1) simpleGrading (1 1 1) // bloc 2, sota del generació hex (0 0 3 4 9 9 12 13) base (2 3 1) simpleGrading (1 1 1) // bloc 3, 1/8 cilindre esquerra hex (0 4 5 6 9 13 14 15) base (3 4 1) simpleGrading (1 1 1) // bloc 4, rectangle ); edges ( arc 1 2 (-30 0 0) arc 2 3 (-30 0 0) arc 3 4 (0 -30 0) arc 8 7 (-20 0 0) arc 10 11 (-30 0 10) arc 11 12 (-30 0 10) arc 12 13 (0 -30 10) arc 16 17 (20 0 10) ); boundary ( blocMetalic { type patch; faces ( (1 10 11 2) ); } aillant { type patch; faces ( (1 0 9 10) (0 6 15 9) ); } aigua { type patch; faces ( (3 2 11 12) (4 3 12 13) (5 4 13 14) (6 5 14 15) ); } ); mergePatchPairs ( ); // ************************************************************************* // Thanks in advance!
Web site where I present my Master's Thesis: foamingtime.wordpress.com The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in! Last edited by zfaraday; November 25, 2013 at 15:04. Reason: changed what is painted in red (radial to angular) |
November 26, 2013, 08:33 |
Alex
Rep Power: 21 |
Well, I've been trying other ways to define that mesh and I finally found the way you can see in the attached picture and in the blockMeshDict file pasted here:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // /* Mapa conceptual .7/9 /|\ / | \ / 2·5 \ 10/15. /|\ \ / \. | \ \ / /11/16\ \ / / | \ \ / / | \ \ 12/17.__.___20.21___.__.6/8 | 0/3 | 1/4 .________. 13/18 14/19 */ convertToMeters 0.001; vertices ( (-20 0 0) //vertice 0 ( 20 0 0) // 1 (0 20 0) // 2 (-20 0 10) //vertice 3 ( 20 0 10) // 4 (0 20 10) // 5 (30 0 0) // 6 (0 30 0) // 7 (30 0 10) // 8 (0 30 10) // 9 (-21.213203436 21.213203436 0) // 10 (-14.142135624 14.142135624 0) // 11 (-30 0 0) // 12 (-30 -10 0) // 13 (0 -10 0) // 14 (-21.213203436 21.213203436 10) // 15 (-14.142135624 14.142135624 10) // 16 (-30 0 10) // 17 (-30 -10 10) // 18 (0 -10 10) // 19 (0 0 0) // 20 (0 0 10) // 21 ); blocks ( hex (20 20 1 2 21 21 4 5) (12 6 1) simpleGrading (1 1 1) hex (20 20 2 0 21 21 5 3) (12 6 1) simpleGrading (1 1 1) hex (2 1 6 7 5 4 8 9) (12 3 1) simpleGrading (1 1 1) hex (11 2 7 10 16 5 9 15) (6 3 1) simpleGrading (1 1 1) hex (0 11 10 12 3 16 15 17) (6 3 1) simpleGrading (1 1 1) hex (13 14 20 12 18 19 21 17) (9 5 1) simpleGrading (1 1 1) ); edges ( arc 1 2 (-20 0 0) arc 2 11 (-20 0 0) arc 11 0 (0 -20 0) arc 6 7 (-30 0 0) arc 7 10 (-30 0 0) arc 10 12 (0 -30 0) arc 4 5 (-20 0 10) arc 5 16 (-20 0 10) arc 16 3 (0 -20 10) arc 8 9 (-30 0 10) arc 9 15 (-30 0 10) arc 15 17 (0 -30 10) arc 2 0 (0 -20 0) arc 5 3 (0 -20 10) ); boundary ( blocMetalic { type patch; faces ( (6 7 9 8) ); } aillant { type patch; faces ( (1 6 8 4) (20 1 4 21) (14 20 21 19) ); } aigua { type patch; faces ( (7 10 15 9) (10 12 17 15) (12 13 18 17) (13 14 19 18) ); } ); mergePatchPairs ( ); // ************************************************************************* // The issue mentioned above I found out that it isolates the blocks that the faces belong to when applying laplacianFoam, as it can be seen in the other attached pic. Therefore I need to get rid of those default faces auto defined when I apply blockMesh. I would be really grateful if someone could give me any advice to solve that problem, because I've been trying many tricks the latest days but I still haven't found out the proper way to solve it. Regards.
Web site where I present my Master's Thesis: foamingtime.wordpress.com The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in! |
December 11, 2013, 03:41 |
Thangam Natarajan
default faces usually arise if you have not defined those faces in your boundary definition (in the blockMesh file). In your blockmesh file, you have not defined the top and bottom surfaces and some surfaces within the geometry. I guess you have include these surfaces in the boundary section of your blockMesh file and define them according to your physical problem suitably as patches or walls.I think once you have defined all the surfaces in the geometry and got rid of the default faces, you should be able to process it. Hope this helps. |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[ICEM] Simple pipe meshing - problems with y+ in CFX | Keizers | ANSYS Meshing & Geometry | 23 | January 15, 2015 08:00 |
[ICEM] Problems with meshing a 3D wing w/winglet | cesarcg | ANSYS Meshing & Geometry | 10 | March 18, 2013 12:12 |
[blockMesh] Specifying boundary faces failes in blockMesh | blaise | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2010 03:56 |
ICEM CFD Meshing Problems: Hexa Dominant | Evan | CFX | 6 | July 3, 2006 12:37 |
