[mesh manipulation] mirrorMesh and undoing the joining of patches
Like Tree16Likes
  • 9 Post By chegdan
  • 7 Post By KateEisenhower
Old   September 7, 2011, 18:46
Default mirrorMesh and undoing the joining of patches
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Hello All,
I used mirrorMesh to mirror a mesh (yes I know that's wierd) and it did a wonderful job at joining patches and such. However now I have a problem. Imagine joining a meshed pipe to make a new pipe twice as long as the original. The original had an inlet an outlet and walls. After reflecting, the inlet was removed and I have two outlets (one patch)...one at the top and one at the bottom of type patch. How can I split this outlet patch to get an inlet patch again?
Thanks in advance.
Dan
chegdan is offline   Reply With Quote
Old   September 8, 2011, 16:44
Default [Solved] mirrorMesh and undoing the joining of patches
Daniel P. Combest
So to fix this I used the following steps
1. faceSet to extract the faces from the outlet patch into a set called outletPatch.
2. made of copy of the outletPatch set named inletPatch
3. Used setSet with the command setSet -batch createInletSet.setSet
where createInletSet.setSet was a text file with the line:
faceSet inletPatch delete normalToFace (0 0 1) 0.01
4. Used setSet with the command setSet -batch createOutletSet.setSet
where createOUtletSet.setSet was a text file with the line:
faceSet outletPatch delete normalToFace (0 0 -1) 0.01
5. used createPatch with the lines
        name inlet;
        // Type of new patch
        dictionary
            type patch;
        constructFrom set;
        patches ();
        set inletPatch;
        name outlet;
        dictionary
            type patch;
        constructFrom set;
        patches ();
        set outletPatch;
in a createPatchDict. That was it and it took me all day to do that. Hope this helps someone else.
Dan
Old   November 30, 2011, 19:10
Daniel P. Combest
I had an even simpler method that starts from a combined patch, in my case it was called "outlet".
1. use faceSet and create a set for your combined "outlet" patch, call it "inletOutletSet"
| \\      /  F ield         | OpenFOAM Extend Project: Open source CFD        |
|  \\    /   O peration     | Version:  1.6-ext                               |
|   \\  /    A nd           | Web:      www.extend-project.de                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      faceSetDict;
// Name of set to operate on
name inletOutletSet;
// One of clear/new/invert/add/delete|subset/list
action new;
// Actions to apply to pointSet. These are all the topoSetSource's ending
// in ..ToFace (see the meshTools library).
topoSetSources
    // All faces of patch
    patchToFace
        name "outlet";      // Name of patch, regular expressions allowed
2. now just go to constant/polyMesh/sets and copy the inletOutletSet to a set called inletSet and then rename the existing inletOutletSet to outletSet (leaving two separate and identical sets called inletSet and outletSet)
3. now subtract out the faces from the inletSet and outletSet you don't need using faceSet again. This was relatively easy since my inlet and outlet patches had normal vectors in opposite direction. For my case, to remove the remove the outlet patch faces from the inletSet i used a faceSetDict like
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      faceSetDict;
name inletSet;
action delete;
topoSetSources
      // Faces with normal to within certain angle aligned with vector.
    normalToFace
        normal (0 0 1);     // Vector
        cos     0.01;       // Tolerance (max cos of angle)
and for my outletSet I used a faceSetDict like
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      faceSetDict;
name outletSet;
action delete;
topoSetSources
    normalToFace
        normal (0 0 -1);     // Vector
4. Now use createPatch to create separate patches from your inletSet and outletSet sets using a createPatchDict similar to
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      createPatchDict;
// This application/dictionary controls:
// - optional: create new patches from boundary faces (either given as
//   a set of patches or as a faceSet)
// - always: order faces on coupled patches such that they are opposite. This
//   is done for all coupled faces, not just for any patches created.
// - optional: synchronise points on coupled patches.
// 1. Create cyclic:
// - specify where the faces should come from
// - specify the type of cyclic. If a rotational specify the rotationAxis
//   and centre to make matching easier
// - pointSync true to guarantee points to line up.
// 2. Correct incorrect cyclic:
// This will usually fail upon loading:
//  "face 0 area does not match neighbour 2 by 0.0100005%"
//  " -- possible face ordering problem."
// - change patch type from 'cyclic' to 'patch' in the polyMesh/boundary file.
// - loosen match tolerance to get case to load
// - regenerate cyclic as above
// Tolerance used in matching faces. Absolute tolerance is span of
// face times this factor. To load incorrectly matches meshes set this
// to a higher value.
matchTolerance 1E-3;
// Do a synchronisation of coupled points after creation of any patches.
// Note: this does not work with points that are on multiple coupled patches
//       with transformations.
pointSync true;
// Patches to create.
patchInfo
        name inlet;
        dictionary
            type patch;
        constructFrom set;
        //patches ("inlet");
        set inletSet;
that should be it. I didn't use these dict files exactly, so there could be subtle errors....but, you get the picture.
Cyp, kaifu, JackW and 6 others like this.
Old   October 21, 2015, 08:09
KateEisenhower is on a distinguished road
Dear Daniel,
Thanks for this post. It helped me a lot. However I think this method doesn't work with OpenFOAM 2.3.1. Here are my suggestions:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      faceSetDict;
action new;
topoSetSources
    patchToFace
1*:
setSet
faceSet inletOutletSet new patchToFace outlet
quit
This remains the same.
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      faceSetDict;
name inletSet;
action delete;
topoSetSources
    normalToFace
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      faceSetDict;
name outletSet;
action delete;
topoSetSources
    normalToFace
3*:
setSet
faceSet inletSet delete normalToFace (0 0 1) 0.01
faceSet outletSet delete normalToFace (0 0 -1) 0.01
quit
0.01 is the tolerance, which is defined as the cos of the angle between the specified normal ((0 0 1) in this case) and the face normal. E.g. 0.01 is approximately 90 degrees.
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
pointSync true;
patchInfo
        name inlet;
        dictionary
            type patch;
        constructFrom set;
        set inletSet;
4*:
Set up the following createPatchDict:
|  \\    /   O peration     | Version:  2.3.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
// - always: remove zero-sized (non-coupled) patches (that were not added)
// - always create both halves in one invocation with correct 'neighbourPatch'
//   setting.
// - optionally pointSync true to guarantee points to line up.
// - in polyMesh/boundary file:
//      - loosen matchTolerance of all cyclics to get case to load
//      - or change patch type from 'cyclic' to 'patch'
//        and regenerate cyclic as above
//       with transformations (i.e. cyclics).
pointSync false;
patches
        // Name of new patch
        name inlet;
        // Dictionary to construct new patch from
        patchInfo
            type patch;
            // Optional: explicitly set transformation tensor.
            // Used when matching and synchronising points.
            //transform rotational;
            //rotationAxis (1 0 0);
            //rotationCentre (0 0 0);
            // transform translational;
            // separationVector (1 0 0);
            // Optional non-default tolerance to be able to define cyclics
            // on bad meshes
            //matchTolerance 1E-2;
        // How to construct: either from 'patches' or 'set'
        constructFrom set;
        // If constructFrom = patches : names of patches. Wildcards allowed.
        patches (periodic1);
        // If constructFrom = set : name of faceSet
        set inletSet;
        name outlet;
        patchInfo
            type patch;
        constructFrom set;
        patches (periodic2);
        set outletSet;
Run:
createPatch
Best regards,
Kate
chegdan, kaifu, emjay and 4 others like this.
KateEisenhower is offline   Reply With Quote
mirrormesh
