[snappyHexMesh] cells can not be removed in snappyhexmesh when using stl file
Old   February 5, 2014, 13:36
Default cells can not be removed in snappyhexmesh when using stl file
tjjs is on a distinguished road
Hi, everybody!
I am learning the snappyhexmesh tool in openfoam. I made a stl file by solidworks to define a cylinder surface.
The cells inside the cylinder can be refined, but the cells from the background mesh outside the target domain did not get removed even the locationInMesh was set inside the target domain.
I have check the stl file by "surfaceCheck", it is fine, and it is a closed surface.
Anyone can help me?
Thanks
tjjs is offline   Reply With Quote
Old   February 5, 2014, 13:46
I attach the setting files and stl file in the attachment.
Old   February 5, 2014, 14:31
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Your refinement surface in your castellatedMeshControls section is not actually named "cylinder.stl" it is actually named "outSurface". Change your refinement surface name in the castellatedMeshControls section to actually match what you have defined in your geometry section, and you will see some castellation happening. If you haven't already, there are some great snappyHexMesh presentations out there from past workshops located on the wiki.
chegdan is offline   Reply With Quote
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X gschaider OpenFOAM Installation 136 October 10, 2017 17:25
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 09:07
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 12:41
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
