January 24, 2014, 10:17 |
creating an exit volume mesh
david mckelvey
Rep Power: 12 |
hi
I'm trying to create an exit volume for a pipe simulation, I want to simulate the outflow from the pipe into an exit volume. what would be the best way to do this for OpenFoam? i would like to create a structured mesh for both the pipe and the exit volume i'm new to meshing and would like some advice on the correct way to do this, i've attached an image of the sorta mesh i would like, thanks for helping David |
January 27, 2014, 11:28 |
The best way is the way you are familiar with 1. Use blockMesh. Create mesh for tube (just like for any cylinder), create mesh for exit volume (in one blockMeshDict). You will have two patches of different sizes which are in the same plane - exit patch of the tube and adjacent exit volume wall. Use mergePatchPairs to remove tube exit patch from adjacent wall patch. 2. Use external mesher (gmsh, Salome etc) and convert mesh. |
January 27, 2014, 12:59 |
david mckelvey
Rep Power: 12 |
hi Alexey
thanks for your reply, I was able to use the mergePatchPairs within blockMeshDict to create an exit volume at the end of the pipe and it passed checkMesh, see image however, I have now released that I would need to terminate the pipe in the centre of the exit volume - see second image, I never thought of this before, I'm simulating a pressure wave exiting the pipe. can anyone point me in the right direction to do this, I'm guessing the I would need to do something to the pipe cells within the exit volume any advice would be helpful David |
February 17, 2014, 14:19 |
david mckelvey
Rep Power: 12 |
problem sorted, by using face matching and structuring the mesh around the pipe i was able to solve the problem and get some good results
face matching as described in section 5.3 mesh generation with blockMesh utility - face matching the set of faces that comprise a patch from one block are formed from the same set of vertices as a set of faces patch that comprise a patch from another block; |
Creating Volume mesh from surface mesh | Vivek.oswal | Mesh Generation & Pre-Processing | 0 | August 7, 2015 14:11 |
Courant number blowing up, non-orthogonal mesh? | odellar | OpenFOAM Running, Solving & CFD | 5 | October 22, 2013 19:50 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
