[snappyHexMesh] Change in meshing procedure for propeller from 2.2.2 to 2.3.0
Old   February 18, 2014, 08:34
Default Change in meshing procedure for propeller from 2.2.2 to 2.3.0
Pete Bachant
pbachant is on a distinguished road
Can anyone explain why various meshing processes were changed in the propeller tutorial? It seems that a few were removed/combined.
Version 2.2.2:
#!/bin/sh
cd ${0%/*} || exit 1    # run from this directory
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
# copy propeller surface from resources folder
cp $FOAM_TUTORIALS/resources/geometry/propellerTip.obj.gz constant/triSurface/
# - meshing
runApplication blockMesh
runApplication surfaceFeatureExtract
runApplication snappyHexMesh -overwrite
# force removal of fields generated by snappy
\rm -rf 0
cp -rf 0.org 0
# - generate face/cell sets and zones
#runApplication setSet -batch removeRedundantZones.setSet
#mv log.setSet log.removeRedundantZones.setSet
runApplication topoSet -dict system/removeRedundantZones.topoSetDict
mv log.topoSet log.removeRedundantZones.topoSet
#runApplication setSet -batch createInletOutletSets.setSet
#mv log.setSet log.createInletOutletSets.setSet
runApplication topoSet -dict system/createInletOutletSets.topoSetDict
mv log.topoSet log.createInletOutletSets.topoSet
#runApplication setSet -batch createAMIFaces.setSet
#mv log.setSet log.createAMIFaces.setSet
runApplication topoSet -dict system/createAMIFaces.topoSetDict
mv log.topoSet log.createAMIFaces.topoSet
# - create the inlet/outlet patches
runApplication createPatch -overwrite
# - apply the initial fields
cp -rf 0.org 0
# - create the AMI faces by creating baffles, and then splitting the mesh
runApplication createBaffles -overwrite
runApplication mergeOrSplitBaffles -split -overwrite
Version 2.3.0:
#!/bin/sh
# copy propeller surface from resources directory
# - meshing
runApplication renumberMesh -overwrite
\rm -rf 0
# - create the inlet/outlet and AMI patches
# - test by running moveDynamicMes
#runApplication moveDynamicMesh -checkAMI
# - set the initial fields
cp -rf 0.org 0
pbachant is offline   Reply With Quote
[ANSYS Meshing] Stop the meshing procedure gdimitris ANSYS Meshing & Geometry 4 October 25, 2017 04:20
What are ways to reduce the time taken by fluent and meshing process in phase change. ~Akshay350~ FLUENT 0 March 23, 2017 12:39
what is the procedure for applying dynamic meshing rsaurabh FLUENT 6 July 23, 2016 17:52
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
