Home > Forums > OpenFOAM Meshing & Mesh Conversion
Problem in rotating mesh, please help!
Old   February 26, 2014, 08:26
Default Problem in rotating mesh, please help!
Tony
wzx1989221 is on a distinguished road
Dear Foamers,
I met a tough problem recently. I have a pipe flow case for which streamwise direction is +Z. I wanted to make the axis of the pipe in +X direction so I rotated the mesh by
rotateMesh -constant '(0 0 1)' '(1 0 0)'
After the rotation, I continued the simulation and compared the results with the original one (+Z direction). For velocity field, the values are more or less the same, however, the pressure field went completely wrong. Attached are pressure field for the original one and the rotated one. I checked the coordinates and direction of velocity components, things seemed all right. By the way, I use cyclic boundary condition for my pipe flow. Can anybody give me advice on why the pressure is wrong (is pressure field related to the rotation)?
Please help. Thank you very much.
Tony
wzx1989221 is offline   Reply With Quote
Thread Tools
Trackbacks are On
[ICEM] Rotating Mesh Problem sghosh55 ANSYS Meshing & Geometry 2 October 6, 2013 12:11
Overset MESH problem DFBI 6DOF Ale85 STAR-CCM+ 0 October 1, 2013 12:25
2D Mesh Generation Tutorial for GMSH aeroslacker Open Source Meshers: Gmsh, Netgen, CGNS, ... 12 January 19, 2012 04:52
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
