Home > Forums > OpenFOAM Meshing & Mesh Conversion
Star-CCM+ Mesh Parameters for OpenFOAM?
Old   April 4, 2014, 09:44
Default Star-CCM+ Mesh Parameters for OpenFOAM?
Petr Furmanek
petr.f. is on a distinguished road
Hi all,
I know that the following has already been discussed here, but it's been a while and maybe there is some new knowledge on this matter.
I'm using Star-CCM+ polyhedral mesh for two-phase computations in OpenFOAM (2.3.x). The geometry I'm meshing is quite complex - front end of a car including part of the underhood, hence I have to use the surface wrapper.
But no matter what meshing characteristics (base size, number of prism layers, face quality during surface remeshing, number of optimization cycles and threshold for polyhedral mesher) I use, the resulting mesh always contains some zero area and wrong oriented faces (polyhedral mesher produces the greatest amount, trimmer, which is basically snappyHex, a little bit less and tetrahedral mesher the smallest amount). StarCCM+ mesh analysis shows none of these problems, but checkMesh goes crazy (I use ccm26ToFoam for conversion)
I have removed all bad cells from the mesh
using procedure described here http://openfoamwiki.net/index.php/SetSet (i.e. create set with bad cells, invert mesh, create subset) and replaced boundary condition on the newly created oldInternalFaces with "symmetry". However, OpenFOAM blows up right after the momentum predictor in the first iteration because of the floating point exception.
So, I'd be very glad if anyone could share his experience with any settings for StarCCM+ that ensure no negative volume cells, zero area faces or wrong oriented faces...
Thanks.
petr.f. is offline   Reply With Quote
Old   May 6, 2014, 00:31
ILAM
dreamilam is on a distinguished road
Hi Petr,
I had similar problems with simpleFoam.
you can remove the zero area faces using the zero area faces indicator( split by function) in star CCM.
Negative volume cells can be removed by right clicking on the region and selecting the "Remove invalid cells" option (You might know this already).
I haven't tested it myself.
Pls give it a try and let me know if it works
Regards
ILAM
dreamilam is offline   Reply With Quote
Old   May 7, 2014, 07:09
Petr Furmanek
Hi Ilam and thanks for the response. I know about these StarCCM+ tools, but unfortunately, they don't work perfectly. As for now, I haven't found any settings that would ensure the resulting mesh will be OK for OpenFOAM. The problem may be partially caused ccm26ToFoam as well... At the end I've decided switch to ANSA and snappyHexMesh.
Thread Tools
Trackbacks are On
how to set periodic boundary conditions Ganesh FLUENT 13 January 22, 2014 05:11
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
2D Mesh Generation Tutorial for GMSH aeroslacker Open Source Meshers: Gmsh, Netgen, CGNS, ... 12 January 19, 2012 04:52
Change parameters for Hybrid mesh karananand ANSYS Meshing & Geometry 3 July 18, 2010 16:37
mesh algo for volume mesh in star ccm rohit CD-adapco 1 August 8, 2008 20:44
