[Commercial meshers] Fluent mesh convert to openfoam |
January 6, 2014, 18:02 |
Rep Power: 14 |
Hi
Anyone knows how to convert .msh file into ASCII format file I tried to run command: fluent3DMeshToFoam Elbowpipe.msh I got following errors: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.2-9739c53ec43f Exec : fluent3DMeshToFoam Elbowpipe.msh Date : Jan 06 2014 Time : 22:50:58 Host : "ke-wu" PID : 2950 Case : /Volumes/OpenFOAM-v2.1/OpenFOAM-2.2.2/run/Elbowpipe nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Dimension of grid: 3 Number of points: 49964 Number of faces: 386540 Number of cells: 177107 --> FOAM Warning : Found unknown block of type: "3010" on line 14 --> FOAM FATAL ERROR: Do not understand characters: on line 15 From function fluentMeshToFoam::lexer in file fluent3DMeshToFoam.L at line 748. FOAM exiting What's the main error from the result Many thanks for your help |
January 7, 2014, 04:11 |
Aurelien Thinat
Rep Power: 15 |
Hi itsme,
I'm not sure for a "msh" file, but this kind of error message generaly comes from a case file (*.cas) saved in binary format instead of ASCII format. Have a look in that direction. |
May 2, 2014, 04:38 |
Park SungChan
Hi itsme,
You can save msh as ascii by opening fluent as meshing mode. SungChan |
Display Modes | |
[CAD formats] Can OpenFOAM convert foam mesh to stl? | liying02ts | OpenFOAM Meshing & Mesh Conversion | 10 | December 30, 2018 10:03 |
[Commercial meshers] COnvert FLuent MEsh to openfoam with interface | manuc | OpenFOAM Meshing & Mesh Conversion | 1 | July 25, 2017 03:13 |
[ANSYS Meshing] Convert a Nastran mesh (.bdf) to Fluent mesh (.msh) | dynlevirus | ANSYS Meshing & Geometry | 1 | August 27, 2012 04:06 |
[Commercial meshers] Cannot convert fluent or tgrid hexcore mesh | aerogt3 | OpenFOAM Meshing & Mesh Conversion | 2 | October 22, 2010 11:55 |
[Commercial meshers] Fluent Mesh to OpenFoam: Internal Surface has to be a wall | sebastian | OpenFOAM Meshing & Mesh Conversion | 6 | October 21, 2010 04:36 |
