[mesh manipulation] stitch mesh - problem with boundary |
June 19, 2014, 09:54 |
Hi all,
I'm trying to mesh the following 3 regions. I use the following createPatchDict to merge: - fak12 with fak13 - wall_tubo with wall - fak31 with fak32 Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object createPatchDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // pointSync false; patches ( { // Name of new patch name tubo_inlet; // Dictionary to construct new patch from patchInfo { type patch; } constructFrom patches; patches (fak12 fak13); // If constructFrom = set : name of faceSet // set f0; } { name tubo_asp; patchInfo { type patch; } constructFrom patches; patches (fak31 fak32); } { name wall_TUBO; patchInfo { type patch; } constructFrom patches; patches (wall wall_tubo1); } ); // ************************************************************************* // Then I delete the patches with 0 faces from boundary file. When I perform stitchMesh between fak11 and tubo_inlet I get the following: Code:
Create time Create mesh for time = 0 Coupling patches fak11 and tubo_inlet Resulting (internal) faces will be in faceZone fak11tubo_inletCutFaceZone Note: the overall area covered by both patches should be identical ("integral" interface). If this is not the case use the -partial option --> FOAM FATAL ERROR: Not all zones and patches needed in the definition have been found. Please check your mesh definition. From function void slidingInterface::checkDefinition() in file slidingInterface/slidingInterface.C at line 85. FOAM aborting Can someone help me please? |
June 19, 2014, 12:26 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
