[Other] createBaffles error Converted 0 faces into boundary faces in patches
Old   August 8, 2014, 03:15
Default createBaffles error Converted 0 faces into boundary faces in patches
Bineet Mehra
bineet_aero is on a distinguished road
i am trying to create a very simple blockMesh which im later gonna use for Snappy. My blockMesh is a single block. I want to use createBaffles utility to make some internal patches as boundary patches . Making use of topoSet, i was able to make the SET folder in constant/polymesh and was successful in extracting the patches. But the next step which is to run createBaffles does not work and this error come "Converted 0 faces into boundary faces in patches". createBaffle dict was copied from tutorial oscillatingInletACMI2D. my problem is something similar to that.
Can anyone please let me know why that error is coming ?
bineet_aero is offline   Reply With Quote
Old   November 14, 2014, 08:38
Anonymous
s.tilt is on a distinguished road
Did you ever find the answer to this?? I am having the same problem
s.tilt is offline   Reply With Quote
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 08:26
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
