[snappyHexMesh] Need help to improve my snappyHexMesh mesh
Old   October 6, 2014, 04:10
Default Need help to improve my snappyHexMesh mesh
amine
aminem is on a distinguished road
Hi
I created mesh with snappyHexMesh but I have some
problem to have good mesh (see picture). Can anyone help me to ameliorate my mesh.
|  \\    /   O peration     | Version:  2.3.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version 2.0;
    format ascii;
    class dictionary;
    location system;
    object snappyHexMeshDict;
    castellatedMesh true;
    snap true;
    addLayers true;
    geometry
        cuve1.stl
            type triSurfaceMesh;
            name cuve1;
        cuve2.stl
            name cuve2;
        cuve3.stl
            name cuve3;
        P3.stl
            name P3;
        P4.stl
            name P4;
        shaft.stl
            name shaft;
        P4MRF
            type searchableCylinder;
            point1 ( 0.0 -0.0035 0.0 );
            point2 ( 0.0 0.0465 0.0 );
            radius 0.05;
        P3MRF
            point1 ( 0.0 0.135 0.0 );
            point2 ( 0.0 0.185 0.0 );
            radius 0.05;
    castellatedMeshControls
        features
        refinementSurfaces
            cuve1
                level ( 0 0 );
            cuve2
                level ( 0 0);
            cuve3
                level ( 0 0 );
            P3
                level ( 0 2 );
            P4
                level ( 0 2 );
            shaft
                level ( 0 2 );
            P4MRF
                faceType internal;
                faceZone MRFP4;
                cellZoneInside inside;
                cellZone MRFP4;
                level ( 0 0 );
            P3MRF
                faceType internal;
                faceZone MRFP3;
                cellZone MRFP3;
                level ( 0 0 );
        refinementRegions
            P4MRF
                mode inside;
                levels (( 1E5 2 ));
            P3MRF
                mode inside;
                levels (( 1E5 2 ));
        locationInMesh ( 0.0 0.0 0.05 );
        maxLocalCells 100000;
        maxGlobalCells 2000000;
        minRefinementCells 0;
        nCellsBetweenLevels 1;
        resolveFeatureAngle 30;
        allowFreeStandingZoneFaces true;
        planarAngle 30;
        maxLoadUnbalance 0.10;
    snapControls
        nSolveIter 30;
        nSmoothPatch 3;
        tolerance 2.0;
        nRelaxIter 5;
        nFeatureSnapIter 10;
        implicitFeatureSnap true;
        explicitFeatureSnap true;
        multiRegionFeatureSnap true;
    addLayersControls
        layers
            cuve2
                nSurfaceLayers 3;
            cuve3
                nSurfaceLayers 3;
            P3
                nSurfaceLayers 3;
            P4
                nSurfaceLayers 3;
            shaft
                nSurfaceLayers 3;
        relativeSizes true;
        expansionRatio 1.2;
        finalLayerThickness 0.3;
        minThickness 0.25;
        nGrow 0;
        featureAngle 130;
        slipFeatureAngle 30;
        nRelaxIter 5;
        nSmoothSurfaceNormals 1;
        nSmoothNormals 3;
        nSmoothThickness 10;
        maxFaceThicknessRatio 0.5;
        maxThicknessToMedialRatio 0.3;
        minMedianAxisAngle 90;
        nBufferCellsNoExtrude 0;
        nLayerIter 50;
        nRelaxedIter 20;
        writeVTK false;
        noErrors false;
        layerRecovery 1;
        growZoneLayers false;
        projectGrownUp 0.0;
    meshQualityControls
        maxNonOrtho 65;
        maxBoundarySkewness 20;
        maxInternalSkewness 4;
        maxConcave 80;
        minFlatness 0.5;
        minVol 1.00E-13;
        minTetQuality 1e-15;
        minArea -1;
        minTwist 0.02;
        minDeterminant 0.001;
        minFaceWeight 0.05;
        minVolRatio 0.01;
        minTriangleTwist -1;
        nSmoothScale 4;
        errorReduction 0.75;
    debug 0;
    mergeTolerance 1E-6;
    autoBlockMesh true;
Thanks
aminem is offline   Reply With Quote
Old   October 8, 2014, 03:47
amine
Any ideas???
Old   October 11, 2014, 09:59
Retired Super Moderator
Bruno Santos
Greetings aminem,
You could have been a bit more specific regarding what exactly you want to improve. Either way, the one thing I say that needs work is related to this dictionary block:
        features
You're missing feature edges, therefore the edges are not snapped into place.
You can find a lot of reading material on this and other topics regarding snappyHexMesh, meshing strategies and visual diagnosis in this wiki page: http://openfoamwiki.net/index.php/SnappyHexMesh
Best regards,
Bruno
[snappyHexMesh] Creating very fine, high accuracy mesh with snappyHexMesh JD_Welch OpenFOAM Meshing & Mesh Conversion 10 July 5, 2023 11:50
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
[snappyHexMesh] Snappyhex mesh: poor inlet mesh Swagga5aur OpenFOAM Meshing & Mesh Conversion 1 December 3, 2016 16:59
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
