November 28, 2014, 17:42 |
mesh refinement. Simple Question
vitor spadeto
Rep Power: 11 |
JUST A LITTLE question..If I have 2 cases.. one with more refined mesh...
the results would still not the same in the division points? (in the case of finite volume is not in the contacts between cells, but inside the cells). To my knowledge, the higher the mesh refinement, more details I can at points where data had not yet but which had already cells. The values are still giving the same, both for less refined as more refined, as the simulation system of equations must be solvable. at the point A the values of velocity will be de same, for the case with more refinement and for the case with less mesh refinement example of velocity profile: |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[snappyHexMesh] Disturbance in the mesh after the addition of layers | Dorian1504 | OpenFOAM Meshing & Mesh Conversion | 0 | June 13, 2017 02:27 |
[snappyHexMesh] snappyHexMesh & Mesh around a missile | sasanghomi | OpenFOAM Meshing & Mesh Conversion | 2 | October 15, 2014 19:54 |
killed "snappyHexMesh" | parkh32 | OpenFOAM Pre-Processing | 2 | April 8, 2012 17:12 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
