[CAD formats] Degenerate triangles in STL for use in sHM |
September 20, 2017, 05:22 |
Marc
Rep Power: 8 |
Hello!
I've been working on an STL file (shown in this image): My aim is to use this STL in snappyHeyMesh, however when running the surfaceCheck utility illegalFaces as well as problemFaces appear. In this image the bad triangles can be seen easily: Therefore, I am worried that the final mesh will turn out badly, or not turn out at all! I have previously used a no-thickness version of this STL and although problemFaces appeared the mesh turned out ok. To clarify, I did not make this STL in a CAD software, instead I exported it from a mathematical modelling software called MathMod. So my question is: can this be an issue? If so, what could I do to improve triangle quality while retaining the same shape? Thank you |
September 27, 2017, 10:17 |
Marc
Rep Power: 8 |
I don't want to be one of those guys who solves his problem and does not give any advice for people with the same issue, so here we go:
I found two main options to improve STL quality though third party software:
illegal face, snappyhexmesh, stl file |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 06:01 |
Triangles are degenerate Pointwise | pcm | Pointwise & Gridgen | 4 | July 13, 2017 11:08 |
[snappyHexMesh] Checkinf if SHM stl files are watertight | fracasce | OpenFOAM Meshing & Mesh Conversion | 2 | April 25, 2017 06:50 |
[snappyHexMesh] SHM does not follow STL geometry well | Illmatic | OpenFOAM Meshing & Mesh Conversion | 7 | July 23, 2016 11:07 |
[snappyHexMesh] sHM with cyclic patch on stl geometry | johannesk | OpenFOAM Meshing & Mesh Conversion | 2 | August 21, 2009 09:08 |
