February 3, 2015, 05:49 |
skewness problem in checking mesh!
Duong Tung
Rep Power: 11 |
Dear everybody,
I had a problem with meshing when i tried to mesh a 2D geometry. When I tried to imported the mesh into OpenFoam, I received the information that the skewness was quite high (max skewness: 4.3036) and this influented my results. I want to ask you that how solve this problem? Do I have to change the mesh by ICEM or I can reduce directly the skewness value in OpenFOAM? You can see the mesh in the attached pictures. I think that the quality of mesh is good but I do not know the reason why the skewness is quite high. Thank you very much for all your helps! |
[OpenFOAM.com] Installing on Ubuntu 18.04 | samiam1000 | OpenFOAM Installation | 11 | April 27, 2020 00:01 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
[ANSYS Meshing] Problem with High Skewness Mesh | CFD2016 | ANSYS Meshing & Geometry | 12 | June 8, 2016 01:28 |
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh | sc.park | OpenFOAM Meshing & Mesh Conversion | 1 | March 13, 2016 13:28 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
