[Gmsh] higher order mesh from Gmsh doesn't works--gmshToFoam
Old   February 6, 2015, 05:57
Default higher order mesh from Gmsh doesn't works--gmshToFoam
hewei is on a distinguished road
Hi all,
I found the utility gmshToFoam only works for first-order mesh, is it true?
the second-order mesh will not convert to OpenFOAM successfully, so does anybody know how to convert the higher order mesh? thanks.
hewei is offline   Reply With Quote
Old   February 6, 2015, 07:37
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Here is the list of elements handled by gmshToFoam:
// Element type numbers
static label MSHTRI   = 2;
static label MSHQUAD  = 3;
static label MSHTET   = 4;
static label MSHPYR   = 7;
static label MSHPRISM = 6;
static label MSHHEX   = 5;
So, no high-order meshes.
In fact, meshing the cylinder like you have attached to the message in general does not require high order elements.
alexeym is offline   Reply With Quote
Old   February 6, 2015, 09:39
Thanks!!
so in order to improve the quality of the surface, just adding more points, right?
W.
Originally Posted by alexeym View Post
Old   February 6, 2015, 11:16
Alexey Matveichev
Originally Posted by hewei View Post
Thanks!!
W.
Yes, also you can use mesh grading to increase density just near the surface of cylinder.
Old   February 6, 2015, 13:07
Peter
opedrofunk is on a distinguished road
You might have a look at this:
https://extensions.sketchup.com/en/c...y-tetgen-tools
Some quick screen shots (multi region mesh, smooth mesh gradation):
I wrote this plugin to solve a problem I was having (namely, that design iterations were happening extremely quickly, and the corresponding simulation/setup times needed to be similarly reduced), and decided to release it in case it might help others. It's free, of course.
You can control mesh gradation, refine locally, set regions and boundaries, remove sections of the mesh (holes), etc. It works with tetgen - which, of course you can convert directly to OpenFOAM format with the tetgenToFoam utility, and with gmsh if you want to do additional preprocessing before converting with the gmshToFoam utility.
Anyway, I hope this might be helpful to the community.
Peter
opedrofunk is offline   Reply With Quote
Old   February 6, 2015, 18:12
Thank you very much Alexey!
Old   February 6, 2015, 18:15
Thank you very much Peter, I will learn your work, I believe it will not only help me, but also gives others more choice. Thanks you again!!
Wei
Peter
A high order curvilinear mesh generation(converting) tool is strongly recommended! hyperman Mesh Generation & Pre-Processing 0 June 22, 2018 08:04
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
