Home > Forums > OpenFOAM Meshing & Mesh Conversion
Mesh generating for an annular ring
Old   March 2, 2015, 01:48
Default Mesh generating for an annular ring
Mehdi Asghari
Asghari_M is on a distinguished road
Hi all;
I am investigating the flow into an annular ring. The r and Z components as well as boundary conditions have been specified in the attached picture.
Briefly, the boundary conditions are inlet, outlet and adiabatic(insulated) walls. Really, the geometry is 3D but since the flow & geometry are axisymmetric, they have been presented as 2D in attached file.
How can I generate mesh for this geometry?
Do I have to use wedge type in blockmesh or to generate the mesh by other mesh generator programs such as Gambit and exporting it to blockmesh and paraview?
What's the real solution?
Thanks a lot for any suggested solution.
M.Asghari
Asghari_M is offline   Reply With Quote
Old   March 4, 2015, 08:33
Joachim Herb
jherb is on a distinguished road
With the following commands you find all tutorials using a wedge geometry:
cd $FOAM_TUTORIALS
find . -iname "0*" -type d | while read d ; do grep -ri wedge $d ; done
This one sounds promising: ./multiphase/interFoam/les/nozzleFlow2D/
mkdir -p $FOAM_RUN
cd $FOAM_RUN
cp  -r /multiphase/interFoam/les/nozzleFlow2D/ .
cd nozzleFlow2D
blockMesh
touch test.foam
Got to parafoam / paraview and check the created mesh. This should be a good starting point for you.
jherb is offline   Reply With Quote
Old   March 6, 2015, 04:11
Mehdi Asghari
Dear jherb;
Nozzelflow2D isn't same my case.
For me, the geometry is such as a ring (semi-wedge) according to the new attachment.
Is there the idea for my geometry meshing?
M.Asghari
Old   March 6, 2015, 14:01
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi I would use www.salome-platform.org
Very easy to define geometry and mesh.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
annular ring, mesh generators, wedge type
Thread Tools
Trackbacks are On
How to build current blower fan model in Flotherm eric0722 FloEFD, FloWorks & FloTHERM 1 January 27, 2015 03:06
Problem w/ vortex ring simulation, mesh coarseness parameters? ESC FLUENT 2 September 4, 2012 10:56
2D Mesh Generation Tutorial for GMSH aeroslacker Open Source Meshers: Gmsh, Netgen, CGNS, ... 12 January 19, 2012 04:52
ParaView and Qt 4.3.5 on Mac OS X 10.6 Adrian OpenFOAM 3 August 8, 2010 03:16
[ICEM] generating tetra mesh on various cylinders at the same time karananand ANSYS Meshing & Geometry 2 July 9, 2010 16:34
