March 2, 2015, 00:48 |
Mesh generating for an annular ring
Mehdi Asghari
Hi all;
I am investigating the flow into an annular ring. The r and Z components as well as boundary conditions have been specified in the attached picture. Briefly, the boundary conditions are inlet, outlet and adiabatic(insulated) walls. Really, the geometry is 3D but since the flow & geometry are axisymmetric, they have been presented as 2D in attached file. How can I generate mesh for this geometry? Do I have to use wedge type in blockmesh or to generate the mesh by other mesh generator programs such as Gambit and exporting it to blockmesh and paraview? What's the real solution? Thanks a lot for any suggested solution. M.Asghari Last edited by Asghari_M; March 2, 2015 at 05:19. |
March 4, 2015, 07:33 |
Joachim Herb
Rep Power: 21 |
With the following commands you find all tutorials using a wedge geometry:
cd $FOAM_TUTORIALS find . -iname "0*" -type d | while read d ; do grep -ri wedge $d ; done Code:
mkdir -p $FOAM_RUN cd $FOAM_RUN cp -r /multiphase/interFoam/les/nozzleFlow2D/ . cd nozzleFlow2D blockMesh touch test.foam |
March 6, 2015, 03:11 |
Mehdi Asghari
Dear jherb;
Nozzelflow2D isn't same my case. For me, the geometry is such as a ring (semi-wedge) according to the new attachment. Is there the idea for my geometry meshing? M.Asghari |
March 6, 2015, 13:01 |
Niels Nielsen
Rep Power: 27 |
Linnemann PS. I do not do personal support, so please post in the forums. |
annular ring, mesh generators, wedge type |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
Problem w/ vortex ring simulation, mesh coarseness parameters? | ESC | FLUENT | 2 | September 4, 2012 10:56 |
