March 25, 2015, 09:25 |
Treatment of internal patches
Tim
Rep Power: 11 |
Hey everyone,
first of all I want to say hello since I've always been a quiet reader but now I need some help. I have a .msh meshfile of a burner-geometry that was exported via ICEM. I converted the file with fluent3DMeshToFoam. Problem is that the mesh contains 2 internal patches which I would like to handle as "non existent" because they simply would block the flow - if defined as "solid" - as they seperate the fluid-domain. I've simply tried to delete the two entrys fom the constant/polyMesh/boundary but surprisingly that's not working I've also read about createBaffles but this seems to create internal Faces instead of "deleting" them. My question is: Is there a more or less simple way to to get rid of those patches? Thanks in advance and have a nice day! Tim |
Problem using AMI | vinz | OpenFOAM Running, Solving & CFD | 298 | November 13, 2023 08:19 |
Lagrangian particle tracking cannot be run in parallel for the cases with AMI patches | Armin.Sh | OpenFOAM Running, Solving & CFD | 7 | March 28, 2021 22:33 |
[Commercial meshers] fluentMeshToFoam: "fluent patch type shadow not recognised" | preibie | OpenFOAM Meshing & Mesh Conversion | 28 | March 29, 2017 04:56 |
Possible bug with stitchMesh and cyclics in OpenFoam | Jack001 | OpenFOAM Pre-Processing | 0 | May 21, 2016 08:00 |
Internal Patches : Which boundary conditions? | Gearb0x | OpenFOAM Running, Solving & CFD | 4 | April 21, 2010 14:26 |
