[Other] Overlapping but not interacting geometry? |
November 21, 2022, 16:38 |
Travis
I have a theoretical problem where I'd like to solve for the flow through a long curved pipe, where the pipe curves through more than 360 degrees in the same plane. Think of a long multi-turn helical pipe and I'm interested in the limit as the helix angle goes to zero. Obviously this is not a physically possible geometry.
This results in a toroidal shape, but where the multiple turns of the pipe overlap in space, but do not interact. This makes more sense in cylindrical coordinates where the space at an angle of theta is *not* the same as the space at theta+2pi. For example, I'd like to use cylindrical coordinates and apply a boundary conditions at theta=0 and 1080 degrees. Does anyone have any advice on this? Not sure if this is really a "meshing" problem, but it didn't really fit in any other categories. |
December 28, 2022, 21:56 |
Hrvoje Jasak
Rep Power: 33 |
Interesting.
Unless you are tracking particles or similar, the solver will never find out that the domain is overlapping with itself - and it will work. You may kill post-processing though Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
cylindrical, impossible geometry |
[ANSYS Meshing] Overlapping contact region with cyclic dependencies | mkkim400 | ANSYS Meshing & Geometry | 1 | December 19, 2018 08:02 |
[ANSYS Meshing] CATIA Geometry Generation and Meshing | danielsullivan | ANSYS Meshing & Geometry | 0 | April 3, 2017 21:11 |
Fill CAD Geometry | voldemort | Autodesk Simulation CFD | 0 | July 12, 2016 01:47 |
[CAD formats] translating geometry from Abaqus to OpenFOAM | skuznet | OpenFOAM Meshing & Mesh Conversion | 3 | January 10, 2014 13:49 |
Export geometry file from ansys mechanical | browns6 | Structural Mechanics | 0 | August 27, 2013 16:19 |
