[cfMesh] version 1.1 - Installing Linux installation package |
June 15, 2015, 10:35 |
Rep Power: 12 |
Hello everybody,
I want to check out the new cfMesh version 1.1 on my Ubuntu VM OS. Therefore I downloaded cfMesh-1.1-linux.run from Sourceforge and moved it to the /opt/cfMesh directory. Then I entered Code:
chmod u+x cfMesh-1.1-linux.run Code:
./cfMesh-1.1-linux.run Code:
QSslSocket: cannot resolve SSLv2_client_method QSslSocket: cannot resolve SSLv2_client_method No marker found, stopped after 1.00 MiB. I'd be thankful for any advice. Best regards, Kate |
June 15, 2015, 16:34 |
Tomislav Lugarić
Rep Power: 10 |
Hello Kate!
Thank you for bringing this issue to our attention. It seems the installer file on SourceForge got corrupted. I have reuploaded the file, and it should be OK now. The new file installs on my Ubuntu VM without issue. Please try to download the file again. I am sorry for your inconvenience. |
June 16, 2015, 02:38 |
Rep Power: 12 |
Hello Tomislav,
No problem. And thank you, the installation worked perfectly now. Following the README-cfMesh.txt file I want to copy the tutorials example directory to the run directory. Where are these tutorials? In the /Home/CreativeFields/cfMesh-v1.1 I can only find the folders foam-extend-3.1, Licenses and ReleaseNotes and a few other files. Thank you for your help, Kate |
June 16, 2015, 02:55 |
Tomislav Lugarić
Rep Power: 10 |
Hello Kate!
The tutorials are not installed by default, you need to select them as an option during installation. If selected, they are installed in ~/CreativeFields/cfMesh-v1.1/cfMesh/tutorials. |
June 16, 2015, 03:01 |
Rep Power: 12 |
I am quite sure the installation of the tutorials and one or two other things were checked by default during the installation process. Anyways, I'm willing to try it again. Can you tell me how to uninstall cfMesh in order to start the installation again? Best regards, Kate |
June 16, 2015, 03:05 |
Tomislav Lugarić
Rep Power: 10 |
Hello
There is an uninstaller binary in ~/CreativeFields/cfMesh-v1.1/cfMeshUninstall Also, if you type cfMesh into Unity launcher, you will be offered to run the uninstaler from there |
June 16, 2015, 03:49 |
Rep Power: 12 |
Tomislav,
sorry for the inconvenience. It was like you said, I just forgot to check the fields during the installation process. Kate |
June 16, 2015, 04:17 |
Rep Power: 12 |
Hi again,
I was trying to run the cartesianMesh/asmoOctree tutorial the following way: 1) chmod u+x Allrun (to give it permissions) 2) ./Allrun (to run the script) Unfortunately no mesh was created. I think the problem is the environment $WM_PROJECT_DIR which is not set up properly. Please note that normally I don't work on ubuntu. My log.cartesianMesh reads: Code:
./Allrun: 52: ./Allrun: cartesianMesh: not found Kate |
June 16, 2015, 04:28 |
#9 |
Tomislav Lugarić
Rep Power: 10 |
Hi
Did you try to run it from your native shell or did you run the installed cfMesh shell? If you run your native shell (terminal), you need to source ~/CreativeFields/cfMesh-1.1/foam-extend-3.1/etc/bashrc. If you start the shell by double clicking on the cfMesh shell on the desktop, you have this done automatically. If you cannot run it from the desktop shell, please send me the printout of the env command. |
July 28, 2015, 10:13 |
#10 |
Dominic
I am Using Ubuntu 14.04.2 and have some Problems with cfMesh. 1. During Installation: Could not write Desktop Entry at /home/dom/Desktop/cfMesh_uninstall.desktop 2. also: QSslSocket: cannot resolve SSLv2_client_method QSslSocket: cannot resolve SSLv2_client_method best regards, Dominic |
July 28, 2015, 11:12 |
#11 |
Tomislav Lugarić
Rep Power: 10 |
Hi Dominic!
The first message simply indicates that the installer was not able to create an uninstaller icon on the desktop. This does not affect your ability to run cfMesh, it will only mean you need to go to the installation directory to run the uninstaller. This is usually caused by permission issues in Linux. Perhaps the installer did not have sufficient permissions to create the file. The second message can safely be disregarded. Since we provide only the offline installer, and we do not have an online repository, this will not cause any issues with your installation. Feel free to contact me if you have any issues running cfMesh. Regards, Tomislav |
[Helyx OS] Installing HelyxOS on 32 and 64bit Linux Distributions | wyldckat | OpenFOAM Community Contributions | 16 | December 23, 2016 06:37 |
Installation Problem with ParaView 3.12.0 on Scientific Linux 5.7 | Wley | OpenFOAM Installation | 2 | September 28, 2012 06:06 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 18:56 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
OpenFOAM installation problem on Linux 32bit | kumar | OpenFOAM Installation | 0 | April 27, 2007 05:41 |
