Home > Forums > OpenFOAM Meshing & Mesh Conversion
Function determined refinement region
Old   July 16, 2015, 02:49
Default Function determined refinement region
hekseli
heksel8i is on a distinguished road
Hey!
I would like to manage to make cell split refinement for a region, which, e.g. outer surface is determined as a function. This surface could be for example a parabolic cylinder x^2 + y +z =0 or something else.
Naturally I could always create this kind of surface in .stl or similar format and then use refineMesh+topoSet functionality but I don't find this feasible when playing around and changing similar mesh slightly from case to case.
I would assume that by abusing topoSet feature and some scripting this could be possible.
Any ideas or experience?
Cheers
heksel8i is offline   Reply With Quote
Old   July 23, 2015, 02:17
hekseli
In the end I decided to create parametrized scripts for stl files via openscad and then just refine by using them. Anyway if I have more time in some point I check if this could be possible via existing functions in OF.
Thread Tools
Trackbacks are On
snappyHexMesh Segmentation Fault avd28 OpenFOAM Native Meshers: snappyHexMesh and Others 11 May 11, 2015 20:32
error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Native Meshers: blockMesh 2 March 14, 2012 10:56
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 07:59
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
