[blockMesh] blockMeshing Annular cylinder ?!! |
July 25, 2015, 11:18 |
I am trying to create a annular cyclinder mesh using blockmesh similar to mesh shown below (Its hollow inbetween. Flow occurs only in the annular section) I started with a simple cyclinder and tried deleting the central block/assigning the inbetween plane as wall/etc.... but nothing worked. Please let me know if it is possible to create such a mesh through blockMesh or should i create a geometry and snap it.. Any help/hint would be of great use!!! Thank you very much Regards, Ananthakrishnan |
July 31, 2015, 17:26 |
Alex
Rep Power: 21 |
Hello Ananthakrishnan,
Yes, it is possible to do what you want with blockMesh. It may exist more than one possible approach but I have done something similar following the steps bellow:
Maybe it's not the most straightforward approach, but it worked for me in the past. Hope it helps, Alex
Web site where I present my Master's Thesis: foamingtime.wordpress.com The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in! |
May 7, 2019, 06:51 |
#3 | |
bharadwaz
Rep Power: 7 |
name cathode; // name of the set type cellSet; action new; // creating a new set or add source cylinderAnnulusToCell; // using a selection box sourceInfo { p1 ( 0 0 0.03 ); // start point on cylinder axis p2 ( 0 0 0.07 ); // end point on cylinder axis outerRadius 0.009 ; innerRadius 0.004 ; } } |
Display Modes | |
Flow past a 2D cylinder - High Re (1E+05) - Cd too high | Pervispasco | OpenFOAM Running, Solving & CFD | 4 | March 14, 2022 03:19 |
Drag force coefficient too high for a flow past a cylinder using komega sst | Scabbard | OpenFOAM Running, Solving & CFD | 37 | March 21, 2016 17:16 |
Forces Acting on a Rotating Cylinder (Moving Mesh) | dreamchaser | CFX | 5 | April 25, 2015 07:01 |
Incorrect Drag and Drag Coefficient for flow over a cylinder | ozzythewise | Main CFD Forum | 8 | June 13, 2012 07:24 |
[blockMesh] Specifying boundary faces failes in blockMesh | blaise | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2010 04:56 |
