[blockMesh] Setting up an airfoil cascade case in OpenFoam with block mesh |
August 6, 2015, 11:02 |
Jack
Rep Power: 10 |
Hi all,
I have a geometry for 2D fan blade consisting of (x,y) points, and I wish to run a RANS simulation for the case when the blades are repeated in a 2D cascade. My blade has a rounded trailing edge and so I am thinking about using an O-grid. I wish to create my mesh using blockMesh. Does anyone have an example where they have done this or can help me out as to where I should start? Many thanks in advance. |
August 6, 2015, 11:32 |
Rep Power: 12 |
I have an octave script which reads the airfoil data and creates a blockMeshDict:
To start type in ysour terminal "octave meshgen_modified_octave.m" You need geo_LS and geo_US.dat in the same folder as your script. Maybe this is a good start for you |
August 6, 2015, 11:39 |
Jack
Rep Power: 10 |
Great thanks! I actually had something similar for my meshing of an airfoil in a free stream, but I'm not sure how to proceed in order to make a cascade out of this! Thanks for your help.
block mesh, cascade, open foam |
Display Modes | |
Setting up LES of Airfoil in OpenFoam | Jack001 | OpenFOAM | 4 | April 12, 2020 03:09 |
[Commercial meshers] openfoam: Interpolating available solution in a new case with a new mesh | gggiulio | OpenFOAM Meshing & Mesh Conversion | 2 | April 15, 2017 13:55 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[Commercial meshers] Icem Mesh to Foam | jphandrigan | OpenFOAM Meshing & Mesh Conversion | 4 | March 9, 2010 02:58 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
