January 4, 2016, 03:30 |
CheckMesh error
Fatemeh
Rep Power: 10 |
Hi every one!
Would any one please please please help me with my problem? I have a 3d open channel. after editting the blockMesh and running check Mesh, the following error appears: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.2-9240f8b967db Exec : checkMesh Date : Jan 04 2016 Time : 11:35:20 Host : "fatemeh-Lenovo-IdeaPad-P400-Touch" PID : 3975 Case : /home/fatemeh/Desktop/B23 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 689931 faces: 1929200 internal faces: 1790800 cells: 620000 faces per cell: 6 boundary patches: 4 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 620000 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 1000 1111 ok (non-closed singly connected) walls 74400 75141 ok (non-closed singly connected) outlet 1000 1111 ok (non-closed singly connected) atmosphere 62000 62721 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (0 -5 -0.012948) (13 5 0.2) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-7.98207e-17 1.53335e-16 6.11549e-15) OK. ***High aspect ratio cells found, Max aspect ratio: 4.38289e+196, number of cells 10286 <<Writing 10286 cells with high aspect ratio to set highAspectRatioCells Minimum face area = 1.24047e-07. Maximum face area = 0.00601414. Face area magnitudes OK. Min volume = 2e-300. Max volume = 4.4999e-05. Total volume = 9.19087. Cell volumes OK. Mesh non-orthogonality Max: 179.968 average: 44.4666 *Number of severely non-orthogonal (> 70 degrees) faces: 214015. ***Number of non-orthogonality errors: 31660. <<Writing 245675 non-orthogonal faces to set nonOrthoFaces ***Error in face pyramids: 68843 faces are incorrectly oriented. <<Writing 37384 faces with incorrect orientation to set wrongOrientedFaces ***Max skewness = 81.1396, 119 highly skew faces detected which may impair the quality of the results <<Writing 119 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 4 mesh checks. End I have attached my blockMesh file in docx format. Would any one please help me with the problem? thanks a lot |
January 5, 2016, 04:47 |
Incorrect Block Definition?
Rep Power: 15 |
I took a quick look at your case and ran checkMesh with the -allGeometry and -allTopology tags. It stated that there were cells with negative volumes (check images). This usually happens when your block is incorrectly defined - up to version 3, OF is very sensitive to the order of your vertices for the blocks. So you might want to double check that. Also, I noticed some vertex components like 0.149004 and 0.15. If they are meant to be the same, you might want to put the same value, 0.15 I guess. The small gap between the components may also be causing trouble. Hope this helps. Cheers, Antimony |
January 5, 2016, 06:07 |
Fatemeh
Rep Power: 10 |
Hi and thanks a lot for your attention and kindness.
In fact, this is a part of of an open channel which the difference between their z coordinates, makes the longitudinal slope of the channel. I have checked the blocks several times and didn't find the error. Would you please tell me which is the best:1-deleting the bad form cells? 2- using gambit for meshing and export it to openfoam? Thanks a lot and best wishes. |
January 5, 2016, 20:45 |
Rep Power: 15 |
You are welcome. I wouldn't recommend deleting off the problem cells. You might end up with a mesh that does not correspond to the geometry you are trying to model. Just as a test, I deleted off the problem cells and the checkMeshLog doesn't look any better than before. You might want to give it a shot with a different mesher perhaps. Cheers, Antimony |
January 5, 2016, 23:56 |
Fatemeh
Rep Power: 10 |
Hi! I am really thankful for what you have done. Ok thanks I will try gambit for meshing. Thanks again and again and best regards
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
