Home > Forums > OpenFOAM Meshing & Mesh Conversion
how to use snappyhexmesh to generate 2D mesh?
Old   January 19, 2016, 04:03
Default how to use snappyhexmesh to generate 2D mesh?
Yage
Yage is on a distinguished road
Dear Foamers,
I would like to run a 2D simulation for a wing-shape geometry, how could I do that with snappyhexmesh?
the refinement level will cut the background in 3D, how to allow it in 2D only?
and is that possible to refine a area, such as level 2, with refineMesh dict with automatic buffer layer generation?
Regards,
Yage
Yage is online now   Reply With Quote
Old   January 19, 2016, 04:40
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Look at cfmesh instead for 2D
Picture taken from their userguide.
They also have tutorialfiles for making a 2D mesh.
Even better if the geo is simple make it a structured mesh using Salome.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   January 27, 2016, 09:03
matej forman
matejfor is on a distinguished road
snappy is not a good idea for 2D, as you have pointed out, it refines in 3D allways.
The solution is to use blockMesh to generate 2D structured mesh (see:
http://www.openfoam.com/documentatio...#x25-1410005.3
and:
https://github.com/OpenFOAM/OpenFOAM...b2434eb3e2c4ed)
or you may try unstructured foamyQuadMesh. see tutorials in $FOAM_TUTORIALS/mesh/foamyQuadMesh
Happy foaming
Matej
matejfor is offline   Reply With Quote
Thread Tools
Trackbacks are On
problem with snappyHexMesh kanes OpenFOAM Native Meshers: snappyHexMesh and Others 10 January 26, 2016 07:11
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
Layers:problem with curvature giulio.topazio OpenFOAM Native Meshers: snappyHexMesh and Others 10 August 22, 2012 09:03
SnappyHexMesh not generate mesh first time mavimo OpenFOAM Mesh Utilities 4 August 26, 2008 07:08
