[Commercial meshers] a question about "fluentMeshToFoam" |
February 29, 2016, 04:21 |
CFD_Lovers
Rep Power: 11 |
hi friends!
i am trying to use command "fluentMeshToFoam" to building a .msh file that created in Gambit, in OpenFOAM. but when i use this command . it seems to half of the operations are truly worked, but half of them are faild!! beacause i can see these messages ( i put just the errors here): #0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigSegv::sigHandler(int) in "/opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 in "/opt/openfoam221/platforms/linux64GccDPOpt/bin/fluentMeshToFoam" #4 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #5 in "/opt/openfoam221/platforms/linux64GccDPOpt/bin/fluentMeshToFoam" Segmentation fault (core dumped) what is the matter? and i should say that after this there is no result in "polyMesh" directory, that we usually expecting to see the results of mesh building in this directory( polyMesh i mean) . All the best! |
March 8, 2016, 02:57 |
Alex
Rep Power: 12 |
Well, if you created the file in Gambit and you try to convert it to FOAM, why don't you just use gambitToFoam instead of exporting the Gambit mesh converted for fluent and then convert it from fluent to FOAM? I could think of conversion errors that occur on that way.
March 17, 2016, 06:40 |
Rep Power: 13 |
Is your .msh 2D? Because fluentMeshToFoam is for 2D meshes. For 3D .msh conversion use fluent3DMeshToFoam.
March 22, 2016, 17:28 |
#4 | |
Rep Power: 11 |
beep-beep |
Question about symmetry in Autodesk Cfd 2016 | ecto | Autodesk Simulation CFD | 0 | October 20, 2015 04:16 |
small question about the functionalities of topological changes in OpenFoam | ngj | OpenFOAM Running, Solving & CFD | 2 | February 28, 2013 10:02 |
Question Re Engineering Data Source | imnull | ANSYS | 0 | March 5, 2012 13:51 |
internal field question - PitzDaily Case | atareen64 | OpenFOAM Running, Solving & CFD | 2 | January 26, 2011 15:26 |
Poisson Solver question | Suresh | Main CFD Forum | 3 | August 12, 2005 04:37 |
