Home > Forums > OpenFOAM Meshing & Mesh Conversion
foamToEnsight & foamToVTK
Old   May 5, 2016, 15:33
Default foamToEnsight & foamToVTK
Ruggero Poletto
rupole1185 is on a distinguished road
Dear foamers,
here I am with few questions about mesh and data translation from OpenFOAM.
I would like to have VTK or Ensight files from my openfoam data, but none of the two readers above really satisfy me because:
1) foamToVTK creates multiple VTK files, each of which is readable by paraview. What is missing is the VTM file that connects multiple time/iterations in just one place
2) foamToEnsight works smoothly and also when I run the ens_checker everything seems ok. But when I open it with Paraview (v5.0.1) I jet "insufficient time values!!!" and then it crashes. I tried to edit the .case file many time but insuccesfully ..
Anyone has experienced something similar?
___________________________
President of CONSELF, the new CFD company with a great cloud solution. Try for free it here!
rupole1185 is offline   Reply With Quote
Old   May 7, 2016, 05:46
akidess's Avatar
Anton Kidess
1) If you run foamToVTK -time X:Y, then you will get resuts as BASENAME_COUNT.vtk. Paraview will recognize files with the same basename to belong together and let you load them in one go as BASENAME_....vtk.
2) foamToEnsight makes one .case file per time step. The Ensight Gold case file documentation is actually decent, if you have a look you should be able to create a case file for all your time steps. At the end of the case file you have a list of time values (e.g. 5.001, 5.002, 5.003, ...) which you are probably missing.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
*Join the OpenFOAM stackexchange Q&A site: http://area51.stackexchange.com/prop...oHPxcPqde7HtA2
akidess is online now   Reply With Quote
Old   May 7, 2016, 07:57
Ruggero Poletto
Yep. Thanks .. The trick with vtk files was really useful.
Regarding the case file instead I think I found a bug on paraview ... Because it can't handle what ensight can ... Should I add this to bug-trackibg system?
Old   May 9, 2016, 02:18
akidess's Avatar
Anton Kidess
Sure. Write to Paraview though, not OpenCFD.
Thread Tools
Trackbacks are On
Using FoamToEnsight with Dynamic Mesh Solvers raunakbardia OpenFOAM Post-Processing 0 February 25, 2016 15:01
foamToVTK will have a different values?! And the fvScheme questions. wenxu OpenFOAM Running, Solving & CFD 19 September 21, 2015 20:49
Error during foamToVTK Lana OpenFOAM Post-Processing 4 April 7, 2015 13:08
Command foamToVTK gruber OpenFOAM 0 July 26, 2010 09:44
FoamTOVTK yapalparvi OpenFOAM Post-Processing 3 August 12, 2009 08:19
