[snappyHexMesh] Mixed snappyHexMesh+Fluent case: create new surfaces on existing CAD file |
May 28, 2016, 12:22 |
thomas
Rep Power: 11 |
Hello all,
I have created an CAD-file using Freecad, I want to create the mesh using snappyHexMesh but run the case using Fluent. The problem is that I require two surfaces in order to add two surface heat sources to the mesh.I havenīt been able to create them using Freecad+snappyHexMesh yet. I create the patches with the "surfaceAutoPatch"-command, with which - as far as I know - I canīt create two patches on one surface. Is there another way? Supposing that everything works fine, how can I export the created "cell zones" and patch-data to a Fluent .msh file? Supposing that the mentioned alternative doesnīt work, could I add surfaces to the existing CAD-file in order to set them as surface heat sources in Ansys Meshing or in Fluent? I would really appreciate your help. Thank you very much in advance. |
[Other] Tabulated thermophysicalProperties library | chriss85 | OpenFOAM Community Contributions | 62 | October 2, 2022 03:50 |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
