[Other] Using Smoothed Particle hydrodynamics |
July 5, 2016, 02:28 |
abhishek chawan
Rep Power: 9 |
Hi all, i have a question in using SPH for my solid glass particle impact on Al Plate? the question is
case 1 - I have a solid spherical glass particle of size 0.5 mm and i give a particle size of 0.015, with this i generate around 3489 particles, my question follows in case 2 case 2 - Now imagine i have the same spherical glass particle but with a void ratio of around 0.6, so does it mean i reduce the number of SPH particles by 60 % ? and is this method valid ??? If not then please help me what is the right method to model a particle with high void ratio in the range of 0.6 - 0.7. Regards Abhishek Chawan |
Using Smoothed Particle hydrodynamics in ANSYS | abhishek chawan | Mesh Generation & Pre-Processing | 0 | July 5, 2016 02:31 |
[ANSYS Meshing] Using Smoothed Particle hydrodynamics | abhishek chawan | ANSYS Meshing & Geometry | 0 | July 5, 2016 02:29 |
Using Smoothed Particle hydrodynamics | abhishek chawan | Structural Mechanics | 0 | July 5, 2016 02:25 |
Basic and simple SPH-code questions (smoothed particle hydrodynamics) | Peacekeeper | Main CFD Forum | 2 | March 12, 2014 16:29 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
