[Other] inconsistent number of faces for a cylinder
Old   August 12, 2016, 22:12
Default inconsistent number of faces for a cylinder
Sergio
sergiopb91 is on a distinguished road
Hi to all.
I'm trying to make a simple cylinder but I get the following error:
--> FOAM FATAL ERROR:
Inconsistent number of faces between block pair 1 and 4
From function blockMesh::calcMergeInfo()
in file blockMesh/blockMeshMerge.C at line 217.
I read that this error occurs when there is difference number of cells between blocks. But I have the same number of cells for the blocks:
convertToMeters 0.001;
vertices
(0 11.3137085 11.3137085)
(0 11.3137085 -11.3137085)
(0 -11.3137085 -11.3137085)
(0 -11.3137085 11.3137085)
(0 12.02081528 12.02081528)
(0 12.02081528 -12.02081528)
(0 -12.02081528 -12.02081528)
(0 -12.02081528 12.02081528)
(60 11.3137085 11.3137085)
(60 11.3137085 -11.3137085)
(60 -11.3137085 -11.3137085)
(60 -11.3137085 11.3137085)
(60 12.02081528 12.02081528)
(60 12.02081528 -12.02081528)
(60 -12.02081528 -12.02081528)
(60 -12.02081528 12.02081528)
blocks
hex (0 4 7 3 8 12 15 11) (100 50 50) simpleGrading (1 1 1)
hex (1 5 4 0 9 13 12 8) (100 50 50) simpleGrading (1 1 1)
hex (2 6 5 1 10 14 13 9) (100 50 50) simpleGrading (1 1 1)
hex (3 7 6 2 11 15 14 10) (100 50 50) simpleGrading (1 1 1)
hex (3 2 1 0 11 10 9 8) (100 50 50) simpleGrading (1 1 1)
edges
arc 3 0 (0 0 16)
arc 0 1 (0 16 0)
arc 1 2 (0 0 -16)
arc 2 3 (0 -16 0)
arc 7 4 (0 0 17)
arc 4 5 (0 17 0)
arc 5 6 (0 0 -17)
arc 6 7 (0 -17 0)
arc 11 8 (60 0 16)
arc 8 9 (60 16 0)
arc 9 10 (60 0 -16)
arc 10 11 (60 -16 0)
arc 15 12 (60 0 17)
arc 12 13 (60 17 0)
arc 13 14 (60 0 -17)
arc 14 15 (60 -17 0)
boundary
inlet
type patch;
faces
(7 3 0 4)
(4 0 1 5)
(5 1 2 6)
(6 2 3 7)
(0 3 2 1)
outlet
type patch;
faces
(15 11 8 12)
(12 8 9 13)
(13 9 10 14)
(14 10 11 15)
(8 11 10 9)
Wall
type wall;
faces
(7 4 12 15)
(4 5 13 12)
(5 6 14 13)
(6 7 15 14)
mergePatchPairs
Someone can help me? and tell me which is the error.
Thanks in advantage
sergiopb91 is offline   Reply With Quote
Old   August 17, 2016, 06:11
Antimony is on a distinguished road
Your block 1 is defined as:
This means that for the edge connecting vertices 0 and 1, there are 50 divisions.
However, in your block 4, defined as:
There are 100 divisions for the edge connecting vertices 0 and 1.
Consequently you have the problem of inconsistent number of faces between the two blocks...
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   August 17, 2016, 10:19
Sergio
It's already working.
Thank you very much for your help Antimony.
[snappyHexMesh] Layers not growing at all zonda OpenFOAM Meshing & Mesh Conversion 12 June 6, 2020 11:28
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
