Home > Forums > OpenFOAM Meshing & Mesh Conversion
A simple question about snappy
Old   March 11, 2009, 04:30
Default After great difficulty I was f
Prapanch Nair
prapanj is on a distinguished road
After great difficulty I was finally able to use snappyHexMesh to mesh the external flow domain about a geometry I had. I am soon writing a tutorial about that, because I couldn't find good tutorials for snappy elsewhere.
My problem now is with setting boundary conditions. I have a rectangular block created using blockMesh. I had set the boundaries inflow and outflow etc. How will I set the boundary condition for the STL geometry's surface? In what Dict file do I set it? can I just add the surface in the boundary file in polyMesh directory?
After running snappy I got two folders 0.001 and 0.002. Do I have to copy the contents of these into a "constant" folder for running a solver on it?
I know my questions are so primitive. Please bear with me. Thank you
prapanj is offline   Reply With Quote
Old   March 11, 2009, 04:50
Default Hi Prapanj, Did you use a s
Marco Müller
marico is on a distinguished road
Hi Prapanj,
Did you use a single STL file?
every STL-region in STL-file (ASCII) starts with "solid NAME", where NAME is probably not present. (and ends with "endsolid NAME").
These regionnames, if present, are kept up by sHM and added to the boundary-file. So your problem is probably, how to assign the names to the regions. If you have only one region it might be easy to just add it manually.
How did you get the STL-File? When using "Salome" it is "relativly" easy to import IGES/STEP, name face-regions and export as single STL-files. (every region one STL-file, which can be called by sHM).
The polyMesh in last folder, here 0.002 (as it is the mesh after snapping), should be copied in "constant" folder to move on, at least I do so.
Best Regards
Marco
also check:
http://www.cfd-online.com/OpenFOAM_D...s/1/11251.html
and:
http://www.cfd-online.com/OpenFOAM_D...tml?1236240810
marico is offline   Reply With Quote
Old   March 11, 2009, 05:06
Default I am currently using only a si
Prapanch Nair
I am currently using only a single STL file that I pulled out of the internet. I was having the question about the multiple STLs. I found a thread that talks about a script to use with blender, so that we can get named ascii STLS without having to manually copy each STL and make it one file. Anyway, the link you provided was really helpful. I get a clearer picture now. Thank you.
Old   March 11, 2009, 05:25
Default you can also use the multiple
Marco Müller
you can also use the multiple files for sHM, just as one STL-file in geometry-definition.
Salome works on my OpenSUSE well and I guess the interface is more familiar than the one of Blender.
Marco
Old   April 28, 2009, 16:44
Default snappyHexMesh tutorial?
xianghong wu
wendywu is on a distinguished road
Hi, I found your turorial, very useful.
Thank you very much.
Wendy
wendywu is offline   Reply With Quote
Old   May 6, 2009, 07:30
Prapanch Nair
Hi Wendy, I am sorry, I haven't uploaded my tutorial on the internet anywhere. How did you find, what did you find?
Old   May 6, 2009, 10:18
Default tutorial for snappyHex Mesh
xianghong wu
Hi, sorry, Maybe I made a mistake. I found a tutorial , I thought it was yours.
Because I saw that your are going to give a tutorial , then I found one after that, I thought it was yours accordingly. I was careless. Sorry, will you give another tutorial?
Wendy
Thread Tools
Trackbacks are On
Snappy snap controls and featureEdgeMesh podallaire OpenFOAM Bugs 9 August 31, 2011 17:42
Unit conversion in Snappy prapanj OpenFOAM Meshing & Mesh Conversion 3 March 12, 2009 23:09
A simple question. yaseer Main CFD Forum 0 March 12, 2007 14:32
A simple question Chandra Shekhar Main CFD Forum 0 January 31, 2005 03:44
Simple question reader Main CFD Forum 1 July 14, 2003 13:29
