[blockMesh] Most efficient way of adding a number of small (gas) inlets, compared to cell size
Old   November 9, 2009, 18:52
Default Most efficient way of adding a number of small (gas) inlets, compared to cell size
kjetil is on a distinguished road
I would like to distribute, say 10, rather small inlets with a cross section ~3mm radially on a pipe where the diameter is 20cm. First, I find it difficult to add this "manually" using blockMesh, but having had a look under the mesh transformation utilities I wonder if there are any clever ways of doing this using these functions? Is there a way to "add"/merge the geometry of inlet patches to an existing mesh?
Thank you.
kjetil is offline   Reply With Quote
Old   November 10, 2009, 02:33
bhh
Bjorn H. Hjertager
bhh is on a distinguished road
In this case I would use the opensource package salome (http://www.salome-platform.org/)for building the geometry and meshing it.
rgds
Bjorn
bhh is offline   Reply With Quote
Old   November 11, 2009, 05:35
Right. So Salome is meshing too?
By the way, is it possible to stitch an imported (Gambit) mesh with a mesh from blockMesh? I can't really figure how to do this in stitchMesh.
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 09:23
parallel run OpenFoam Srinath Reddy OpenFOAM Running, Solving & CFD 13 February 27, 2019 09:15
GenerateVolumeMesh Error - Surface Wrapper Self Interacting (?) AndreP STAR-CCM+ 10 August 2, 2018 07:48
foam-extend_3.1 decompose and pyfoam warning shipman OpenFOAM 3 July 24, 2014 08:14
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
