[swak4Foam] FunkySetFields for cyclic bc
Old   December 18, 2007, 06:01
Default FunkySetFields for cyclic bc
Zaki Saldi
zakifoam is on a distinguished road
Dear all,
I want to run a simulation of a 2-D rayleigh-taylor instability case using interFoam. I have a heavy liquid (gamma=1) lying on the top of light liquid (gamma=0). In blockMeshDict, I set the left and right boundaries as cyclic. I set the initial gamma field using funkySetFields utility. The command is:
funkySetFields . RH1-cyclic -time 0 -field gamma -expression "1.0" -condition "pos().y>=0" -keepPatches
so the interface of both fluids is at y = 0 (at bottom boundary y = -0.1, at top y = 0.1)
However, I ended up having gamma=0.5 at left & right boundaries, as shown below.
Any idea how I can make the boundary values similar to the internal values?
Thanks a lot
zaki
zakifoam is offline   Reply With Quote
Old   December 18, 2007, 07:24
Default solved the problem. Cyclic
Zaki Saldi
solved the problem.
Cyclic boundaries should've been set as a single patch in blockMeshDict. So my problem had nothing to do with funkySetFields.
[swak4Foam] groovyBC and funkySetFields married and got a kid named swak4Foam gschaider OpenFOAM Community Contributions 169 August 10, 2023 09:01
[swak4Foam] how to use funkySetFields function in muliregion case bryant_k OpenFOAM Community Contributions 15 October 15, 2021 02:50
[swak4Foam] funkySetFields and funkySetBoundaryFields zxj160 OpenFOAM Community Contributions 19 February 14, 2018 19:07
[swak4Foam] funkySetFields: problem with processor boundary nmikhailov OpenFOAM Community Contributions 4 May 26, 2015 09:48
[swak4Foam] funkySetFields Chrisi1984 OpenFOAM Community Contributions 10 June 17, 2010 03:26
