[blockMesh] BlockMeshmergePatchPairs polyTopoChanger |
May 14, 2008, 02:23 |
Ruben I. Mukhamadeev
Rep Power: 17 |
I try to create 3D geometry with 3 elements: pipe (inlet) + box + pipe (outlet). Mesh is attached here.
blockMeshDict As i understand (reading Manual & Forum), to support continuity of fluid domain it is need to use mergePatchPairs for outlet of the 1-st pipe and inlet of the 2-nd pipe. But blockMesh writes it: Exec : blockMesh . mars-b Date : May 14 2008 Time : 06:00:48 Host : r117-1 PID : 5933 Root : /home/ben/OpenFOAM/ben-1.4.1/run/tutorials/rhoTurbFoam Case : mars-b Nprocs : 1 Create time Reading block mesh description dictionary Creating block mesh Creating blockCorners Creating curved edges Creating blocks Creating patches Creating block mesh topology Default patch type set to empty Check block mesh topology Basic statistics Number of internal faces : 16 Number of boundary faces : 34 Number of defined boundary faces : 34 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list . Creating points Creating cells Creating patches Creating mesh from block mesh Default patch type set to empty Creating merge patch pairs Adding point and face zones Creating attachPolyTopoChanger #0 Foam::error::printStack(Foam:stream&) in "/home/ben/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/home/ben/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0xb7eef420] #3 Foam::face::ray(Foam::Vector<double> const&, Foam::Vector<double> const&, Foam::Field<foam::vector<double> > const&, Foam::intersection::algorithm, Foam::intersection::direction) const in "/home/ben/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #4 Foam::slidingInterface::projectPoints() const in "/home/ben/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libdynamicMesh.so" #5 Foam::slidingInterface::changeTopology() const in "/home/ben/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libdynamicMesh.so" #6 Foam::polyTopoChanger::changeTopology() const in "/home/ben/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libdynamicMesh.so" #7 Foam::polyTopoChanger::changeMesh(bool, bool) in "/home/ben/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libdynamicMesh.so" #8 Foam::attachPolyTopoChanger::attach(bool) in "/home/ben/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libdynamicMesh.so" #9 main in "/home/ben/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/blockMesh" #10 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #11 Foam::regIOobject::readIfModified() in "/home/ben/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/blockMesh" Segmentation fault Could abybody explain whats wrong ? Need help ! ruben |
May 14, 2008, 07:05 |
Gurus, could you describe a pr
Rep Power: 17 |
Gurus, could you describe a procedure of coupling for simple geometries (and meshes) ? How to describe continuation - absence of the wall - between defined geometries) ? For instance - in the case above i could't describe it neither with mergePathPairs nor with stitchMesh - i have not undestood how to do it from Manual/Forum. It would be nice to see a simple case of geometry coupling and meshing for it with blockMesh (and, perhaps, it would be placed in Manual or one of tutorial directory of distribution).
ruben |
May 14, 2008, 07:53 |
The same case, with deleting o
Rep Power: 17 |
The same case, with deleting of patches "in-box" and "from-box", deleting of mergePatchPairs - using blockMeshDict mesh could be generated. But using checkMesh will see :
Exec : checkMesh . mars-b Date : May 14 2008 Time : 11:44:43 Host : r117-1 PID : 7173 Root : /home/ben/OpenFOAM/ben-1.4.1/run/tutorials/rhoTurbFoam Case : mars-b Nprocs : 1 Create time Create polyMesh for time = constant Time = constant Mesh stats points: 264103 edges: 775860 faces: 759760 internal faces: 728240 cells: 248000 boundary patches: 4 point zones: 0 face zones: 0 cell zones: 0 Number of cells of each type: hexahedra: 248000 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Point usage OK. Upper triangular ordering OK. Topological cell zip-up check OK. Face vertices OK. Face-face connectivity OK. *Number of regions: 3 The mesh has multiple regions which are not connected by any face. <<Writing region information to "constant/cellToRegion" Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface inlet 80 89 ok (not multiply connected) outlet 80 89 ok (not multiply connected) wall 31200 31234 ok (not multiply connected) defaultFaces 160 178 ok (not multiply connected) Checking geometry... Domain bounding box: (0 0 0) (0.4962 0.87 0.397) Boundary openness (1.24596e-16 3.85683e-14 1.84074e-17) OK. Max cell openness = 1.9423e-16 OK. Max aspect ratio = 16.7631 OK. Minumum face area = 2.69769e-06. Maximum face area = 7.65262e-05. Face area magnitudes OK. Min volume = 1.52595e-08. Max volume = 1.46484e-07. Total volume = 0.0192304. Cell volumes OK. Mesh non-orthogonality Max: 74.8213 average: 34.162 *Number of severely non-orthogonal faces: 14659. Non-orthogonality check OK. <<Writing 14659 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 3.69783 OK. Min/max edge length = 0.000658 0.0186173 OK. All angles in faces OK. Face flatness (1 = flat, 0 = butterfly) : average = 0.999992 min = 0.999792 All face flatness OK. Mesh OK. End So - i have a mesh with 3 independent volumes and defaultFaces between them. Using which tools could meshes be coupled together ? Need help ! ruben |
June 29, 2008, 21:24 |
hi all.
i have 4 blocks to be
nikhil babu madduri
Rep Power: 17 |
hi all.
i have 4 blocks to be merged in a particular manner. i have named the walls which are not to be merged with any other faces as 'patch0'(patch followed by a number representing the patch number). And i have named the patches which have to be merged as merge01-1 for example for the face which is involved in the merge between a face of block 0 and another face of block 1. and the last number '1' says that the face is belonging to block '1'. So this is the following blockMeshDict file obtained: (please look for problems in mergePatchPairs in particular. coz if i delete either second line or third line in mergePatchPairs, it was working fine at the cost of not being able to merge that deleted merger) /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.4.1 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ // FoamX Case Dictionary. FoamFile { version 2.0; format ascii; root "/home/nikhil/OpenFOAM/nikhil-1.4.1/run/tutorials/icoFoam"; case "cavityGrade"; instance "constant/polyMesh"; local ""; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // arguments "/home/nikhil/OpenFOAM/nikhil-1.4.1/run/tutorials/icoFoam/cavityGrade" off; convertToMeters 0.001; vertices ( (0 0 0) (10000 0 0) (10000 10000 0) (0 10000 0) (0 0 9750) (10000 0 9750) (10000 10000 9750) (0 10000 9750) (0 0 9750) (10000 0 9750) (10000 10000 9750) (0 10000 9750) (0 0 10250) (10000 0 10250) (10000 10000 10250) (0 10000 10250) (10000 0 9750) (20000 0 9750) (20000 10000 9750) (10000 10000 9750) (10000 0 10250) (20000 0 10250) (20000 10000 10250) (10000 10000 10250) (10000 0 0) (20000 0 0) (20000 10000 0) (10000 10000 0) (10000 0 9750) (20000 0 9750) (20000 10000 9750) (10000 10000 9750) ); blocks ( hex (0 1 2 3 4 5 6 7) (30 30 30) simpleGrading (1 1 1) hex (8 9 10 11 12 13 14 15) (30 30 30) simpleGrading (1 1 1) hex (16 17 18 19 20 21 22 23) (15 30 3) simpleGrading (1 1 1) hex (24 25 26 27 28 29 30 31) (30 30 30) simpleGrading (1 1 1) ); edges ( line 0 1 line 3 2 line 7 6 line 4 5 line 0 3 line 1 2 line 5 6 line 4 7 line 0 4 line 1 5 line 2 6 line 3 7 line 8 9 line 11 10 line 15 14 line 12 13 line 8 11 line 9 10 line 13 14 line 12 15 line 8 12 arc 9 13 (9750 0 10000) arc 10 14 (9750 10000 10000) line 11 15 line 16 17 line 19 18 line 23 22 line 20 21 line 16 19 line 17 18 line 21 22 line 20 23 arc 16 20 (10250 0 10000) line 17 21 line 18 22 arc 19 23 (10250 10000 10000) line 24 25 line 27 26 line 31 30 line 28 29 line 24 27 line 25 26 line 29 30 line 28 31 line 24 28 line 25 29 line 26 30 line 27 31 ); patches ( wall patch0 ( (0 1 5 4) (0 4 7 3) (3 7 6 2) (1 0 3 2) ) wall patch1 ( (9 13 12 8) (8 12 15 11) (11 15 14 10) (10 14 13 9) (12 13 14 15) ) wall merge01_0 ( (4 5 6 7) ) wall merge01_1 ( (9 8 11 10) ) wall patch2 ( (16 20 23 19) (19 23 22 18) (18 22 21 17) (17 21 20 16) (20 21 22 23) ) wall merge32_2 ( (16 19 18 17) ) wall merge03_0 ( (2 6 5 1) ) wall merge03_3 ( (24 28 31 27) ) wall merge32_3 ( (30 31 28 29) ) wall patch3 ( (25 29 28 24) (26 30 29 25) (27 31 30 26) (25 24 27 26) ) ); mergePatchPairs ( (merge01_0 merge01_1) (merge32_2 merge32_3) (merge03_3 merge03_0) ); // ************************************************** *********************** // and i was getting the following error in the terminal window. Cud anyone please suggest me what the problem might be: /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.4.1 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : blockMesh /home/nikhil/OpenFOAM/nikhil-1.4.1/run/tutorials/icoFoam cavityGrade Date : Jun 30 2008 Time : 09:21:11 Host : localhost PID : 23034 Root : /home/nikhil/OpenFOAM/nikhil-1.4.1/run/tutorials/icoFoam Case : cavityGrade Nprocs : 1 Create time Reading block mesh description dictionary Creating block mesh Creating blockCorners Creating curved edges Creating blocks Creating patches Creating block mesh topology Default patch type set to empty Check block mesh topology Basic statistics Number of internal faces : 0 Number of boundary faces : 24 Number of defined boundary faces : 24 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list . Creating points Creating cells Creating patches Creating mesh from block mesh Default patch type set to empty Creating merge patch pairs Adding point and face zones Creating attachPolyTopoChanger --> FOAM FATAL ERROR : Error in point ordering: mixed used and unused points at the end of point list. Number of used points: 88939 and point 88987 is used by a live face.#0 Foam::error::printStack(Foam:stream&) in "/home/nikhil/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/nikhil/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Foam::polyMesh::initMesh() in "/home/nikhil/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #3 Foam::polyMesh::resetPrimitives(int, Foam::Field<foam::vector<double> > const&, Foam::List<foam::face> const&, Foam::List<int> const&, Foam::List<int> const&, Foam::List<int> const&, Foam::List<int> const&, bool) in "/home/nikhil/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #4 Foam::polyTopoChange::changeMesh(Foam::polyMesh&, bool, bool) in "/home/nikhil/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libdynamicMesh.so" #5 Foam::polyTopoChanger::changeMesh(bool, bool) in "/home/nikhil/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libdynamicMesh.so" #6 Foam::attachPolyTopoChanger::attach(bool) in "/home/nikhil/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libdynamicMesh.so" #7 main in "/home/nikhil/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/blockMesh" #8 __libc_start_main in "/lib/i686/libc.so.6" #9 Foam::regIOobject::readIfModified() in "/home/nikhil/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/blockMesh" From function void polyMesh::initMesh() in file meshes/polyMesh/polyMeshCalcFaceCells.C at line 153. FOAM aborting Thank you, nikhil. |
Polytopochanger broken in 15x due to mesh format change | andersking | OpenFOAM Bugs | 6 | January 19, 2009 04:34 |
