-   OpenFOAM Meshing & Mesh Conversion (http://www.cfd-online.com/Forums/openfoam-meshing/)
-   -   OpenFOAM workshop mesh handling and generation (http://www.cfd-online.com/Forums/openfoam-meshing/61623-openfoam-workshop-mesh-handling-generation.html)
andrewpjackson March 12, 2008 07:13
Dear All, This is a reminde
Dear All,
This is a reminder to anyone working in the area of OpenFOAM mesh generation, moving mesh or any other related meshing tasks. If they would
like to present in the forthcoming "mesh handling and generation" session in the OpenFOAM workshop in Milan the closing date for a short a
bstract on their work is the 31st March 2008.
regards
Andrew Jackson
http://www.openfoamworkshop.org/08/i...itle=Main_Page
vinz March 18, 2008 09:47
Hi Andrew, I am preparing a
Hi Andrew,
I am preparing an abstract on high quality grid generation for OpenFOAM.
Should I send it to you or somebody else?
Regards,
Vincent
cps July 17, 2012 07:43
disappearing internal wall after conversion
Hello All,
Just I am trying to work with OpenFoam and appears problem with internal wall.
I used Centaur export mesh to fluent cas and convert this mesh in to OpenFOAM.
Unfortunately , I lost a info subject internal wall.
I believe that is some method for create a mesh included internal wall for OpenFOAM.
I open for any suggestion, what kind of free tools should I use for proper mesh generating.
I would like to setup a pressure wall drop on this internal wall
before conversion into OpenFOAM
| inlet ~~~~ :~~~~~~~ | outlet
: -- internal wall
after conversion
| inlet ~~~~ ~~~~~~~ | outlet
P.S. I am a fresh OpenFOAM user and I am open for cooperation with OpenFOAM expert.
Thanks and regards,
Joe
mturcios777 July 17, 2012 12:34
Do a search for threads about baffles, internal/zero thickness walls, and the createBaffles and mergeOrSplitBaffles utilities. That should give you a good start.
In a nutshell, you'll need to select the faces that used to be part of the internal wall and turn them into baffles.
On a side note, please include screenshots or sketches in the future; the ASCII drawing you made is very difficult to see what you want, and the formatting on different browsers can cause it to appear distorted/different than you want.
