-   OpenFOAM Meshing & Mesh Conversion (http://www.cfd-online.com/Forums/openfoam-meshing/)
-   -   CheckMesh for mesh quality (http://www.cfd-online.com/Forums/openfoam-meshing/61630-checkmesh-mesh-quality.html)
gdbaldw October 16, 2007 10:13
To all, checkMesh tells me
To all,
checkMesh tells me I have one concaveFace, but as can be seen in the attached image this white face owned by the purple cell does not appear to be concave. In general, does checkMesh simply screen for possible mesh errors? I ask because this is not the first time checkMesh produced an error/warning for what appeared to me to be a good mesh.
Doug
http://www.cfd-online.com/OpenFOAM_D...ges/1/5700.jpg
mattijs October 16, 2007 14:09
Concavity check should pick up
Concavity check should pick up where consecutive edges form a normal (right-hand rule) which points opposite to the face normal. Can't see any problems with the code itself (OpenFOAM/lnInclude/primitiveMeshCheck.C).
Does the wireframe of the concave face show the same? (VTK does not display solid concave faces correctly)
gdbaldw October 18, 2007 00:11
Mattijs, You are absolutely
Mattijs,
You are absolutely correct. Identical views of this face displayed in paraFoam as a surface and as a wireframe are attached below. Thank you for making this clear for me.
Doug
http://www.cfd-online.com/OpenFOAM_D...ges/1/5713.jpg
http://www.cfd-online.com/OpenFOAM_D...ges/1/5714.jpg
