[Commercial meshers] Only one boundary patch after gambitToFoam conversion |
August 22, 2007, 05:37 |
Hi all,
I tried to convert a Gambit .neu mesh using gambitToFoam, which worked fine, but I ended up with only one single boundary patch. Is there something obivous I have overlooked, or what do I have to do to get the boundary dictionary right? Cheers, Benjamin |
August 22, 2007, 06:01 |
Hi Benjamin,
can you explain
Cedric DUPRAT
Rep Power: 17 |
Hi Benjamin,
can you explain what you did with gambit, cause I used also gambitToFoam with more than one boundary patch successfully. check that your solver is Generic, and that all your boundaryPatch are defined as ELEMENT_SIDE (you can change them later on FoamX). hope it helps, regards, Cedric |
August 22, 2007, 10:19 |
Hi Cedric,
thank you for yo
#3 | |
Hi Cedric,
thank you for your quick answer. I actually import the mesh from CFD-GEOM into gambit. I now realised that the boundary patches were already gone after importing to gambit and changed that, but now I get this error when executing gambitToFoam: Quote:
Cheers, Benjamin |
August 22, 2007, 10:30 |
...works now :-) Thanks again!
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
