FoamMeshToFluent
Hey All,
I'm currently working on a comparison between openFOAM and cfx, and therefore I need meshes in both formats. I started with the forward- and backward-facing steps of the tutorials and converted it with foamMeshToFluent without any error message. After that I tried to load the mesh into icemCFD to convert it to the cfx format. But an error occured which is obviously due to the last part of the converted fluent-mesh. Here a lot of 4s appear, which seems quite strange and looks like that: ... 4 299b 299c 2938 2937 13ba 0 4 29ff 2a00 299c 299b 141e 0 4 2a63 2a64 2a00 29ff 1482 0 )) (12 (1 1 1482 1 0)( 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 ... 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4)()) (39 (1 fluid fluid-1)()) (39 (2 interior interior-1)()) (39 (10 pressure-outlet inlet)()) (39 (11 pressure-outlet outlet)()) (39 (12 symmetry bottom)()) (39 (13 symmetry top)()) (39 (14 pressure-outlet obstacle)()) (39 (15 pressure-outlet defaultFaces)()) I also tried to convert the openFOAM mesh after solving the problem, as this converter is presented as a post-processing tool but I got the same results. Does anyone know if this is a bug, or if this must be due to an input problem??? Or has anyone already a converted mesh of the tutorial examples (forward- or backward-facing step). Cheers Florian |
Hi Florian,
just create you
Hi Florian,
just create your mesh in ICEM, saving it as *.geo (CFX4) or *.msh (Fluent) and use OF's "import"-converters, works perfect! Peter. |
Hi Peter,
thanks for the hint
Hi Peter,
thanks for the hint. I tried it that way (cfx4) but none of the patches was defined in the boundaries-file. Where did you define the patches withihn icemCFD, so that they are overtaken from OF? I defined them in the BCs in the output area, before writing out the cfx4-file. The above mentioned problem is solved somehow. I tried to import the fluent-mesh generated by foamMeshToFluent into CFX-Pre directly and it worked! |
Hi Florian,
first, select C
Hi Florian,
first, select CFX4 as the solver in ICEM. To get the *.geo-File (cfx4) you need to specify the boundary conditions from the Output-tab first. After that, do File>>Blocking>>Save Multiblock Mesh... This creates the boundary-files. Now the Write Input/Output command should work fine! Peter |
