[mesh manipulation] Problem when defining a mesh |
July 5, 2006, 09:59 |
Gabriele Ottino
Rep Power: 17 |
I have this problem. Let consider a single edge, for example a linear horizontal edge: I have to obtain a grid which is finer at the start and at the end of the edge, and coarser in the middle. So, I don't know if there is a command that allows us to do it or if there is another method to do it. Somebody can help me, please? Best regards, Gabriele |
July 5, 2006, 14:42 |
You'll need to use two blocks,
Mattijs Janssens
Rep Power: 26 |
You'll need to use two blocks, each having opposite grading. See e.g. the pitzDaily tutorial
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[Other] Mesh Importing Problem | cuteapathy | ANSYS Meshing & Geometry | 2 | June 24, 2017 05:29 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Mesh is doing some problem | prwl120 | FLUENT | 2 | May 21, 2015 14:05 |
