[Other] Addremove Layer mesh
Old   August 20, 2004, 05:02
Default Addremove Layer mesh
Chalothon Thumthae (Thumthae)
Can the solver "engineFoam' work with layer addition and removal? I run the example and seen when the piston moving up, all mesh seem to be small but did not eliminated.
I see FOAM have layerAdditionRemoval class in SAE paper. I think FOAM is very powerful code, it have many utilities, but the problem is user do not know how to use it.
Old   August 23, 2004, 14:08
Default Dear Chalothon Thumtae, th
Mattijs Janssens (Mattijs)
the standard engineFoam code has no layer addition and removal built-in.
(In-house we have various bits and pieces working regarding mesh topology - v.s. just geometry - changes but are still actively developing this aspect of Foam)
If you require specialist help you can always approach us for commercial support.
Regards,
Mattijs
[snappyHexMesh] Creating very fine, high accuracy mesh with snappyHexMesh JD_Welch OpenFOAM Meshing & Mesh Conversion 10 July 5, 2023 11:50
[snappyHexMesh] SnappyHexMesh - no layer added bejbro OpenFOAM Meshing & Mesh Conversion 5 February 1, 2020 20:05
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
