ideasUnvToFoam / anaysToFoam Errors
All,
I'm trying to run the following conversion ideasUnvToFoam 4bb_offset_20.unv and am receiving the following error: cannot open file file: /root/OpenFOAM/root-1.6/system/controlDict at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 62. FOAM exiting I don't have a /root/OpenFOAM/root-1.6/system/controlDict path... is there a varaiable I'm missing? Any suggestions are appreicated. /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.6-f802ff2d6c5a Exec : ideasUnvToFoam 4bb_offset_20.unv Date : Aug 30 2009 Time : 11:12:56 Host : localhost.localdomain PID : 11799 Case : /root/OpenFOAM/root-1.6 nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time cannot open file file: /root/OpenFOAM/root-1.6/system/controlDict at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 62. FOAM exiting |
Hi
you need a /system/controlDict file like in the other OpenFOAM cases for the ideasUnvToFoam to work. Create a new folder an just copy the system folder from one of the tutorial cases, put the unv in the folder you created and run the command again. Regards |
That did the trick.. Thanks
have a control dict file but still get the error
Guys,
I have the controlDict file however i still get the same error any ideas? |
