-   OpenFOAM Meshing & Mesh Conversion (http://www.cfd-online.com/Forums/openfoam-meshing/)
-   -   Manually divide sub-domain for parallel computing (http://www.cfd-online.com/Forums/openfoam-meshing/68111-manually-divide-sub-domain-parallel-computing.html)
duongquaphim September 7, 2009 12:00
Hi all,
I am working with parallel computing in OpenFoam and I would like to divide my computational domain into two sub-domains at an exact position.
How can I manually set up the parameters to define a position of an interface between two sub-domains instead of just using simple method that OpenFoam supported? I would not like to manually define every cell of my domain with manual method since it is impossible.
Thank you.
Duong
Ralph M November 18, 2012 12:10
Hello Duong,
It's some time ago since you posted this; did you manage to find a solution?
I would be interested in your findings!
Regards,
Ralph
vbchris November 19, 2012 15:50
You need to use a decomposeDict file in /constant.
It looks like this
FoamFile
version 2.0;
format ascii;
class labelList;
location "constant";
object decompDict;
0
0
... // These are the mesh cells in order as defined in blocks in blockMeshDict, so for a 2D block with 10x10 cells this would have 100 entries
1
Then modify your decomposeDict to refernce your decomposeDict File
Like this:
numberOfSubdomains 8;
method manual;
simpleCoeffs
n ( 4 1 1);
delta 0.00000001;
hierarchicalCoeffs
n ( 2 2 1 );
delta 0.001;
order xyz;
scotchCoeffs
processorWeights
( 1 1 1 1 1 1 );
manualCoeffs
dataFile "decompDict"; // Here is where your point to decompDict
distributed no;
roots ( );
Ralph M November 20, 2012 02:52
Dear Chris,
Thanks for clearing this up. Is there a way to automatically generate the file which is located in constant? I found a way to generate this file based on one of the other decomposition methods (decomposePar -cellDist) but I'm looking for a way to define the cells in another way.
Cheers,
Ralph
vbchris November 20, 2012 17:47
I made the file manually. For 70 000 cells took about 5 minutes in a spread sheet.
But the split wasn't that complicated. You can check the decompose in paraview after by /processor0/paraFoam.
Ralph M November 21, 2012 03:00
For 4 million cells and often a lot of calculations it would be another story though ;)
Regards,
Ralph
cuba November 26, 2012 12:00
Originally Posted by vbchris (Post 393046)
0
0
1
are 0 and 1 processor numbers?
the row-wise order of 0's btw the brackets specifies the cell ID ?
Thanks
Ralph M November 26, 2012 13:33
Yes, the numbers define the processor which is used... they are ranked on cell number in one row.
Try
for an arbitrary case and you'll see the output in a file in the "constant"-folder.
Cheers!
kalle November 28, 2012 02:38
I guess it cannot be impossible to write a simple OF-tool that reads in cellSets or cellZones and based on those creates the decomposeDict. Then, you could control domain decomposition using the setSet utility!
Ralph M November 28, 2012 03:08
I figured this already out ;) But anyway (on behalf of future readers); thanks for the hint!
Bernhard November 29, 2012 03:11
Maybe you can use setFields to define the values in the blocks, and then change the header files a bit?
