[swak4Foam] Problem with compiling swak4Foam
Old   September 10, 2013, 06:43
Default Problem with compiling swak4Foam
The_Architect is on a distinguished road
Hey fellow OpenFOAMers,
I'm trying to install the swak4Foam in order to use the groovyBC, however I run into trouble when running the ./Allwmake, the output is really long and appears to have some problems, please find the attachment.
I am running OpenFOAM 2.2.1 on Ubuntu 12.04 LTS. I have followed the instructions for swak given at http://openfoamwiki.net/index.php/Contrib/swak4Foam.
All help will be appreciated!
The_Architect is offline   Reply With Quote
Old   September 10, 2013, 07:10
Assistant Moderator
Bernhard Gschaider
Which version of swak are you using. Because with the last releases compilation would have stopped after the first failure.
The problem is that the coordSet.H-header moved to a different location in OF2.2. The problem was taken care of on the 9th of March so the fix should be in the releases 0.2.3 and 0.2.4
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   September 10, 2013, 08:22
Thank you Bernhard,
I tried with the 0.2.4 release, but it seems that there still are a few errors with the compilation.
Old   September 10, 2013, 17:19
Retired Super Moderator
Bruno Santos
Greetings to all!
@The_Architect: See this post: http://www.cfd-online.com/Forums/ope...tml#post434217 post #8
edit: I've updated the wiki page about this issue: http://openfoamwiki.net/index.php/Co...am#Downloading
Best regards,
Bruno
Old   September 11, 2013, 06:24
Thank you Bruno, it works now!
[swak4Foam] swak4foam >>>> INSTALLATION PROBLEM steven123 OpenFOAM Community Contributions 35 January 11, 2021 16:53
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 11:32
[swak4Foam] fails in parallel with -otherTime? Phicau OpenFOAM Community Contributions 3 June 26, 2013 13:00
[swak4Foam] installation problem: "./Allwmake: ... [[: not found" Rajarshi OpenFOAM Community Contributions 8 May 13, 2013 08:05
COMPILING PROBLEM ammi FLUENT 1 December 7, 2006 04:07
